It is currently Sun Jun 21, 2026 9:14 pm
 Post subject: Head and intake porting
PostPosted: Sun Jun 01, 2008 7:12 pm
Is there a template or guide out there for porting the slant six head? I've done a pretty decent gasket matching job, but I don't know where to go from there.
Also, is there anything to be done porting wise for an Offenhauser 4 bbl intake?
Stephan Nelle
 Post subject: Nope...
PostPosted: Sun Jun 01, 2008 7:49 pm
just make sure to get the 'burrs' out of the ports, shave some off the valve guide area, unless you are running O/S valves and high compression.... you won't need to do too much to the head for improvements on the street....
-D.idiot
PostPosted: Sun Jun 01, 2008 8:27 pm
The head is in the shop right now getting o/s valves and has been milled .100 What else can I do to the head noting those modifications?
Stephan Nelle
PostPosted: Mon Jun 02, 2008 5:14 am
Hey Pinkiedog,
How much did they charge you for the whole job (oversized valves, seats, and milling)?
-Mac
