| Hitachi 4bbl's? https://slantsix.org/forum/viewtopic.php?t=29219 |
| Author: | Rug_Trucker [ Thu May 29, 2008 9:46 pm ] |
| Post subject: | Hitachi 4bbl's? |
The carb idea article sounds nice. It jogged my memory about the RX-4 Mazda truck a guy used to have. It had a rotary engine with a 4bbl down draft Hitachi carb! Maybe a neat idea for the fairly stock slant? |
| Author: | emsvitil [ Thu May 29, 2008 10:13 pm ] |
| Post subject: | Mazda Carbs...... |
Is old news.......... http://www.slantsix.org/forum/viewtopic ... carb#83750 |
| Author: | SlantSixDan [ Fri May 30, 2008 5:33 am ] |
Did we ever figure out what-all Mazda models used this kind of carb? |
| Author: | emsvitil [ Fri May 30, 2008 5:43 am ] |
Quote: Did we ever figure out what-all Mazda models used this kind of carb?
The carbed rotary engine models (R100,RX2,RX3,RX4, RX7 and the rotary truck) had a 4bbl carb.
| Author: | argentina-slantsixer [ Fri May 30, 2008 11:11 am ] |
if memory serves is a zenith stromberg carb. We concluded with Ed that it would be "the" 4 barrel carb for a mild stock or mildly hopped up slant. |
| Author: | DusterIdiot [ Fri May 30, 2008 7:16 pm ] |
| Post subject: | Lol... |
Quote: The carbed rotary engine models (R100,RX2,RX3,RX4, RX7 and the rotary truck) had a 4bbl carb.
I had a buddy with one of those on a 1983 RX7... zippy car... but after a while the carb tanks (the odo on my buddy's car was like 80K...he was the second owner) and becomes an annoying nuisance....-D.Idiot |
| Author: | emsvitil [ Fri May 30, 2008 10:40 pm ] |
| Post subject: | Re: Lol... |
Quote: Quote: The carbed rotary engine models (R100,RX2,RX3,RX4, RX7 and the rotary truck) had a 4bbl carb.
I had a buddy with one of those on a 1983 RX7... zippy car... but after a while the carb tanks (the odo on my buddy's car was like 80K...he was the second owner) and becomes an annoying nuisance....-D.Idiot The R100 was 60 cuin, so probably has the smallest carb, plus there weren't very many of them The RX2 and RX3 were 70 cuin The RX4 and truck were 80 cuin So there's probably two different carbs. BTW, a rotary behaves like a normal 4-stroke engine at double the stated capacity (70=140, 80=160) BTW2, rotaries like high rpm (at least 7000 rpm redline) BTW3, Each induction stroke on a rotary is half the stated capacity 70 = 35 cuin; 80 = 40 cuin. Compared to a 225 = 37.5 cuin. Plus with the intact manifold on a rotary, each rotor only sees 1/2 the carb; so each piston on a slant will see the whole carb.... you shouldn't have any problems with the carb size |
| Author: | Rug_Trucker [ Sat May 31, 2008 7:11 am ] |
Just for reference I couldn't find any on EBAY. It may be a really hard item to find. |
| Author: | SlantSixDan [ Sat May 31, 2008 7:34 am ] |
I found several on eBay: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0257602843 http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0024054176 http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0256464200 I also found a lot of Weber conversion kits on offer, which suggests to me that this miniature Japanese 4bbl may be a problematic unit. |
| Author: | Rug_Trucker [ Sat May 31, 2008 8:32 am ] |
Don't think those are the Hitachi's. They look like the space station there Dan!! Looks like enough crap on there to make me run away! I would think an RX-4 truck carb by virtue of being a "truck" would have less crap on it. |
| Author: | DusterIdiot [ Sat May 31, 2008 12:51 pm ] |
| Post subject: | Yep... |
Quote: Don't think those are the Hitachi's.
They look just like the carb on my buddy's Rx-7... -D.Idiot |
| Author: | emsvitil [ Sat May 31, 2008 3:09 pm ] |
That last carb SSD posted has a lot of crap on it.............. Don't need all the extras...... The Hitachi's may be for the 13B engine (80cuin) and not the 12A (70cuin)... The webers are for race ported rotaries, not very streetable. |
| Author: | Wizard [ Sat May 31, 2008 3:28 pm ] |
| Post subject: | how come? |
EH? Weber is very tuneable and I was able to get MPG. Mine is 32/36 DFEV. I'm referring to few models that are "race-only" webers especially ones that does not have vacuum advance port. Also, there are many that can do MPG like DCOEs. but no port for advance vacuum. Cheers, Wizard |
| Author: | argentina-slantsixer [ Sat May 31, 2008 4:34 pm ] |
back in the early 70's when chrysler started with electronic ignition many hack job mechanics and many good ones hurried to cut wires and retrofit points because "electronic ignition ain't good". This has been that way around cars forever. Just because you see peopl offering webber conversion kits (BTW I think that webber is a nice carburetor if you have a noisy red little italian car) ain't means that hitachis, solex mikunis, mikunis, pierburg solex or other makes are not good. Most of those rather obscure carburetors outperforms webbers by waaay too much. For 2 barrels options if you're looking for optimum bang on the low end and killer mileage, plus crisp throttle response and nice power, AISAN are very good carburetors. primary is 26 mm secondary is 32, you can run a single carb on a stocker or 2 x 2 barrels on a hopped up motor. Those came in toyota celicas from late 70's early 80's. |
| Author: | emsvitil [ Sat May 31, 2008 4:53 pm ] |
The webers for rotaries are these: http://www.racingbeat.com/FRmazda1.htm scroll down half-way....... |
