| fuel system https://slantsix.org/forum/viewtopic.php?t=2925 |
| Author: | andrew wagner [ Fri Nov 30, 2001 5:52 pm ] |
| Post subject: | fuel system |
I just wanted to get your take on the holley 110gpm 14psi electric pump? And is there a way to get a 3/8 supply line from the stock tank? And does the return line have to go back to the tank or can it go back to the line before the pump? It's a 69 dart. THANK YOU!! andrew wagner |
| Author: | Charlie Schmid [ Sat Dec 01, 2001 9:41 am ] |
| Post subject: | Re: fuel system |
: I just wanted to get your take on the holley : 110gpm 14psi electric pump? And is there a : way to get a 3/8 supply line from the stock : tank? And does the return line have to go : back to the tank or can it go back to the : line before the pump? : It's a 69 dart. : THANK YOU!! : : andrew wagner Andrew, does that pump require a return line? What i did on my barracuda. I took an extra fuel sender/pickup unit, and modified it with a 3/8 ilne going down and to the rear of the tank. Also a 5/16 line just to the inside of the bung, for a return. The ideal way would have the return going above fuel level, but you can't install the sender unit with one line going up and one line going down. You do want the return going to the tank, though, for fuel/pump cooling. Charlie flturbo6@aol.com |
| Author: | Bob D [ Mon Dec 03, 2001 7:18 pm ] |
: I just wanted to get your take on the holley : 110gpm 14psi electric pump? And is there a : way to get a 3/8 supply line from the stock : tank? And does the return line have to go : back to the tank or can it go back to the : line before the pump? : It's a 69 dart. : THANK YOU!! : : andrew wagner Andrew, To get the 3/8" supply line you can purchase a sending unit for a 440 A-body from Year One (P/N FA69), or you could re-build your own with a 3/8" line using the old 5/16" line as a template. You'll also need to get the 3/8" filter "sock" that attaches to the supply line. For the return line you can use the Moroso kit from Jegs (P/N 710-65385) or simply solder a 5/16" nipple into the gas tank filler tube. Remove the filler tube first!! Bob D BBobbias@aol.com |
