Newbie Question
https://slantsix.org/forum/viewtopic.php?t=29258
Page 1 of 1
Author:  canadian_jeeper [ Sun Jun 01, 2008 6:04 am ]
Post subject:  Newbie Question
I just acquired a slant 6 from a 1985 dodge pick up going to put it in my jeep and replace the 318 that just blew up, I want to use my existing wiring and ecu box and single ballast resistor now can I use the current distributor on the /6 or do I need to change to an older electronic distributor, also plan on upgrading to a better carb instead of the one barrel on the engine. so what are my distributor options that you would recommend?
Author:  Bren67Cuda904 [ Sun Jun 01, 2008 6:46 am ]
Planning to change trans/bellhousing also?
Author:  canadian_jeeper [ Sun Jun 01, 2008 7:05 am ]
Yes just picked up a /6 727 for it.
Author:  Charrlie_S [ Sun Jun 01, 2008 7:19 am ]
What year/model jeep? Are you wanting to use the jeep ign module or the jeep ECU (computer)? If a newer jeep with ECU , I don't think that will work. If ign module, maybe.
Author:  canadian_jeeper [ Sun Jun 01, 2008 10:22 am ]
Its a cj7 with a 318 in it with electronic distributor and a orange ecu box want to keep wiring the same and drop in slant6
Author:  slantasaurus [ Sun Jun 01, 2008 9:46 pm ]
If the Slant distributor has counter-weights and springs inside of it you should be able to plug and play. If there are no weights and springs inside, it's a Lean Burn distributor and you'll need an older style electronic dizzy.
Author:  canadian_jeeper [ Mon Jun 02, 2008 4:44 am ]
the distributor has two plugs both two wires per plug if that helps i believe the motor is an 85
Author:  SlantSixDan [ Mon Jun 02, 2008 6:58 am ]
The two-plug distributor is what's normally found in an '85 engine, but it won't work for what you want to do. If you want a brand-new one that'll drop into the '85 engine and plug right into your Jeep's existing wiring (though you may have to extend some of the wires to reach the slant-6's different distributor location compared to the V8), you could go snag this one. I've bought a few of these off this seller. Despite his far-flung location, his shipping service is fast and reliable, I've found.
Author:  canadian_jeeper [ Wed Jun 04, 2008 4:27 pm ]
will this work http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0226012827
Author:  SlantSixDan [ Wed Jun 04, 2008 5:11 pm ]
Probably, but a new one's better than a "remanufactured" one, any and every day.
(Could I get you to please read & use the eBay link posting guidelines contained in this post? It makes things a lot easier for everyone who wants to read your post/thread. We don't post eBay's ultra-long web links here; it screws up the board formatting for the whole, entire thread. I've gone ahead and edited your link.)
Author:  canadian_jeeper [ Thu Jun 05, 2008 5:03 pm ]
sorry about the link from ebay didn't know
