| horn problem https://slantsix.org/forum/viewtopic.php?t=29265 |
| Author: | itlldo1 [ Sun Jun 01, 2008 7:06 pm ] |
| Post subject: | horn problem |
Does anyone have a wiring diagram for a '78 D100? Having problems with the horn. I want to see if there is a relay in the circuit. I metered out what I could and found that the sandwhich swich in the steering column was bad (separating foam turned to powder in the last 30 years!) Right now I only make the ground with a test light on certain steering wheel positions. Is this the roller or contact plate acting up? Mike |
| Author: | CARS [ Tue Jun 03, 2008 10:05 am ] |
Fellow slanter wjajr led me to this site: www.mymopar.com/wiringdiagrams.htm Hope it helps you! |
| Author: | KBB_of_TMC [ Wed Jun 04, 2008 9:16 am ] |
Also, you might check that the jumper wire that grounds the column to the dash is still there and in good shape... it usually is right at the clamp that holds the column to the dash. |
| Author: | hellion_locdogg [ Wed Aug 18, 2010 3:11 pm ] |
| Post subject: | This should be a sticky |
if it's not already. ,Cliff |
| Author: | shadetree [ Fri Aug 20, 2010 4:45 pm ] |
| Post subject: | horn stuff |
Yes there is a horn relay. Not listed in haynes or clymers. on my 78 it was on lthe left hand fenderwell.Depending on contact ring a spring from a bic click a poprivet just the round part not the nail. A soldering iron and a short chunk of 16 gauge. Solder wire to mushroom and bottom of spring. Contact strips in horn get grody a little soft pencil eraser will clean it. WHITE wire 18 or 20 ga.is trigger to relay or same ga. yellow some times. Relay may be plug in or eyelet terminal. All I got. lol shadetree |
| Author: | hellion_locdogg [ Fri Aug 20, 2010 6:03 pm ] |
I meant this, sorry. http://www.mymopar.com/wiringdiagrams.htm ,Cliff |
