| Intake manifold types https://slantsix.org/forum/viewtopic.php?t=2927 |
| Author: | tnsguy [ Sat Dec 01, 2001 8:16 am ] |
| Post subject: | Intake manifold types |
I have a 64 Dart with a 225 of unknown origin in it. The intake manifold has an EGR valve on it (I think that is what it is), so I figure it is from a later model. However, there is no vacuum port in the manifold for the PCV valve, so I have to cut the carb mounting gasket to provide the vacuum. Does anyone know what combinations of PCV valve vacuum ports and EGR valve came on which year intake manifold - I'd like to get the correct one for my year, which I'm guessing has a vacuum port and does not have an EGR valve. tomc@abac.com |
| Author: | Charlie Schmid [ Sat Dec 01, 2001 9:28 am ] |
| Post subject: | Re: Intake manifold types |
: I have a 64 Dart with a 225 of unknown origin : in it. The intake manifold has an EGR valve : on it (I think that is what it is), so I : figure it is from a later model. However, : there is no vacuum port in the manifold for : the PCV valve, so I have to cut the carb : mounting gasket to provide the vacuum. Does : anyone know what combinations of PCV valve : vacuum ports and EGR valve came on which : year intake manifold - I'd like to get the : correct one for my year, which I'm guessing : has a vacuum port and does not have an EGR : valve. On my 65 engine the PCV connected to the base of the carb. Charlie flturbo6@aol.com |
| Author: | tnsguy [ Sat Dec 01, 2001 2:56 pm ] |
: On my 65 engine the PCV connected to the base : of the carb. Charlie Mine is the same. THe vacuum port on the carb leads to a hole on the bottom which mates with a similar hole in the intake manifold - at least that is what I think it should do. tomc@abac.com |
