Carter BBD for 318
https://slantsix.org/forum/viewtopic.php?t=29315
Page 1 of 2
Author:  Wesola78 [ Wed Jun 04, 2008 12:16 pm ]
Post subject:  Carter BBD for 318
I have a Carter bbd from a 318 that I'm going to try on my slant six. I'm not worried about choke issues, but I have read in other posts about the 318 bbd carbs having holes in the throttle plates which can affect idling. My bbd has these holes, should I try to avoid a potential issue and use a little jb weld, etc., or should I "cross that bridge" when I come to it?
It's okay if my car is inoperable for a couple of days.
Thanks for the advice!
Wes
Author:  Doc [ Wed Jun 04, 2008 4:58 pm ]
I vote "cross the bridge when you get there".
Try the carb and then adjust it as needed.
Author:  Wesola78 [ Wed Jun 04, 2008 6:48 pm ]
Okay, I'll try it first and see how she does.
Thanks!
Author:  oklahoma joe [ Thu Jun 05, 2008 7:33 pm ]
I have thr v8 bbd carb with holes and no modifications on my 198 slant six and it ran fine before I took the engine apart to be rebuilt.
Joe
Author:  63Dart170 [ Fri Jun 06, 2008 6:21 am ]
Another satisfied 318 user on my slant six without any modification.
Author:  Wesola78 [ Fri Jun 06, 2008 3:26 pm ]
Thanks for the replies fellas!
It has been raining here (D'oh!), but I'll have that carb installed soon.
Thanks again,
Wes
Author:  Wesola78 [ Sat Jun 07, 2008 11:07 am ]
Update: She runs!
My Volare starts right up with it's Offy 4bbl intake and Carter bbd with an adapter. The idle is a little rough, and I still have to install the kickdown linkage (Lokar cable), but at least it's running.
Oh yeah, I have to figure out how I'm gonna attach the air cleaner. I have a stock air cleaner that fits, but there is no screw to hold down the lid. Oh well.
I'll be fiddlin' with the carb for awhile...
Later guys,
Author:  Wesola78 [ Sun Jun 08, 2008 10:25 pm ]
I got the kickdown linkage installed. I also changed the spark plugs, it's been awhile. The idle is still a little rough. I have adjusted the idle mixture screws, is there anything else I should check? It feels like there is a small vacuum leak, I'm wondering if I should plug those two holes in the throttle plates, what do ya'll think?
Thanks in advance for your responses!
Wes
Author:  66aCUDA [ Mon Jun 09, 2008 5:36 am ]
I would temp plug them (not JB weld think bubble gum??) then if you need to take it out you dont mess things up. A vac leak test might be in order.
Frank
Author:  Wesola78 [ Mon Jun 09, 2008 7:22 am ]
Okay, so to temporarily plug the holes, should I use a couple of screws maybe?
Also, I've never done a vacuum leak test. What sort of equipment is required for this?
Thanks for your reply!
Wes
Author:  Rug_Trucker [ Mon Jun 09, 2008 9:06 am ]
JB can be peeled off easily. Screws falling out can damage things.
JB Quick is good to go in 2 hours.
I glued the screws in my BBD that I am rebuilding. They are brass and the shaft got ruined when I pulled it apart.
How's the shaft play on the passenger side?
Don't you have a Weber?
Author:  SlantSixDan [ Mon Jun 09, 2008 10:53 am ]
True and true...but the first of those truths kinda worries me. How do we make sure the JB Weld doesn't flake off on its own?
I've soldered-up these throttle plate holes before. You have to work quickly so as not to warp the plate. Really, I think probably the small-screw-and-nut technique is probably best for a try-it-and-see approach; if I knew for a fact I didn't want the holes, I'd probably look at some kind of a low-profile rivet.
Author:  Rug_Trucker [ Mon Jun 09, 2008 12:41 pm ]
I was stating for a trial. I did peel the excess off after gluing in the screws a week later. No surface prep done.
Author:  Wesola78 [ Mon Jun 09, 2008 7:50 pm ]
Yes, I have a Weber. Actually, two Webers on an Offy dual intake. I removed the whole deal and reinstalled the Offy 4bbl intake with a Carter bbd. I just want a simpler setup, and maybe a little better fuel efficiency.
I have to say that this is a remanufactured Carter bbd from O'Reilly Auto Parts. I know that I'm just asking for trouble, and if I can't get it to work right, I may just go with a new Holley 350 cfm from Summit, Jegs, etc.
But I have a couple of days off now to mess with it some more.
I wonder how one of those Webers on the 4bbl intake would do? Then I would have a spare Weber carb, but I might want to sell this Offy dual Weber carbs setup complete.
I dunno, we'll see. Thanks to all of you for your input. Feel free to comment on anything I've said.
Wes
Author:  Rug_Trucker [ Mon Jun 09, 2008 9:18 pm ]
i WOULD DEFINATELY USE ONE OF THOSE wEBERS!
Page 1 of 2 All times are UTC-07:00
