later speedo cable to '65 dart speedo head. how to?
https://slantsix.org/forum/viewtopic.php?t=29321
Author:  Rapid Robert [ Thu Jun 05, 2008 6:21 am ]
Post subject:  later speedo cable to '65 dart speedo head. how to?
80's 904 in a '65 dart. The threads on the speedo cable are slightly different than the threads on the speedo head under the dash. How do I mate them? Thank you for your time. RR
Author:  SlantSixDan [ Thu Jun 05, 2008 10:02 am ]
The speedo cable needed for this swap is a '66-'67 item. ATP #Y803. You can get it at www.rockauto.com if you can't find it locally.
Author:  Doc [ Thu Jun 05, 2008 10:11 am ]
Does the 904 have the plastic or die cast alum. speedo gear holder, down at the tranny?
Use a 1966 A-Body cable assembly, with the die cast speedo gear holder and all will be good.
Author:  Rapid Robert [ Thu Jun 05, 2008 12:49 pm ]
it has the plastic & I have a alum ones in my stash.
Author:  Rapid Robert [ Thu Jun 05, 2008 5:38 pm ]
I found the alum one & a speedo cable from a parted '66 val & both ends fit. Life is good. it's not what you know it's WHO you know . Thanks guys. now I can find out my mpg :wink:
