It is currently Mon Jun 15, 2026 12:42 am
 Post subject: Dipstick broke off
PostPosted: Thu Jun 05, 2008 7:13 am
The end of my dipstick broke off in the tube. How do i take off the tube/housing to retrieve the broken piece?
thank you much
isaiah6:8
www.kenithomas.com
PostPosted: Thu Jun 05, 2008 9:44 am
It's just pressed in at the block. If you can get some pliers on it closer to the engine block just wiggle it back and forth while pulling up and it should come out. Don't crush the hollow tube.
'63 Valiant V200 Convertible
225 Aluminum Block
PostPosted: Thu Jun 05, 2008 10:00 am
You don't need to remove the broken piece of dipstick. If it's stuck in the tube, use something long and thin to push it the rest of the way in; it'll fall harmlessly to the bottom of the oil pan and stay there. Usually they don't get stuck in the tube, they fall into the pan on their own.
Then you bend the top of the tube inward towards the block a little (so the new dipstick won't get smacked by the crank, which is what breaks them) and replace the stick.
