It is currently Sat Nov 28, 2026 1:41 am
 Post subject: A904 front pump gears
PostPosted: Mon Jun 16, 2008 9:05 pm
My inner front pump gear has been worn on the inside where the torque converter engages the pump. I believe it's worn because the hub of the torque converter was cracked. Do these the pump gears get replaced as a set? I think I'll check my other core's pump and see if it's better.
PostPosted: Mon Jun 16, 2008 9:34 pm
OK, the other (V8 A904) core's inner front pump gear isn't worn as obviously as the one from the /6 A904, but the bore is rougher and about the same maximum diameter of the /6 inner pump gear. The teeth of the V8 pump gear don't look as good as the slant gear. It appears both pump gears are worn on their ID, but the /6 gear just has a more pronounced wear pattern. A and A Transmissions sells pump gear sets so I would imagine so do other, nearer places. I hope that throwing mo' money at this now means fewer problems later.
