| yes....another pertronix question https://slantsix.org/forum/viewtopic.php?t=29471 |
| Author: | Slantcer [ Wed Jun 11, 2008 11:15 pm ] |
| Post subject: | yes....another pertronix question |
So I hooked up the pertronix and its getting spark to the coil wire but no start. I figure it could be 1. the cap or 2. the pertronix module, anybody have this happen? suggestions? new cap is the first step but i think it might be the module. it cought once and sounded like it fired one cylinder but thats it, kinda lost here, any help would be appreciated, |
| Author: | emsvitil [ Thu Jun 12, 2008 12:24 am ] |
When you put a pertronix in, you have to reset the timing as it changes a bit from the stock points....... |
| Author: | Slantcer [ Thu Jun 12, 2008 8:19 am ] |
is 6 deg sufficient? Any particular suggestions? 66 225 in a 61 lancer |
| Author: | SlantSixDan [ Thu Jun 12, 2008 8:32 am ] |
Don't guess...check with a timing light. Usually they'll flash well enough to get you in the ballpark, even just while cranking on the starter. |
| Author: | Slantcer [ Thu Jun 12, 2008 8:38 am ] |
did that, now something just took a crap, it just clicks when the key turns over? i'm at a loss now......... |
| Author: | Slantcer [ Fri Jun 13, 2008 2:21 pm ] |
turns out it was the starter and its an obsolete starter, an old presto, found a rebuilt one. |
