| Changing the water pump https://slantsix.org/forum/viewtopic.php?t=29474 |
| Author: | vornie [ Thu Jun 12, 2008 12:55 pm ] |
| Post subject: | Changing the water pump |
Hi New to forum, everyone seems really helpful which is great. Tomorrow we're gonna try and change an old broken water pump with a new one. Have little to no experience with a slant six 225 petrol engine (in a UK Dodge 50 vehicle http://en.wikipedia.org/wiki/Dodge_50 So any advice/tips/expertise on this procedure would be much appreciated Cheers Vornie |
| Author: | Doc [ Thu Jun 12, 2008 1:21 pm ] |
Drain cooling system. Remove the radiator, fan and pulley. Remove waterpump. Some of the bolts go into the water jacket so carefully work tight ones back and forth to remove with out breaking. It is a nice to flush-out the engine block while the waterpump is off. Clean the gasket surface and replace the short by-pass hose leading to the head, during re-installation DD |
| Author: | SlantSixDan [ Thu Jun 12, 2008 1:34 pm ] |
Ermmm...anything wrong with answers you've already had to this water pump query? |
| Author: | vornie [ Thu Jun 12, 2008 1:43 pm ] |
Not at all love, that post was entitled 'workshop manual' and more to do with the manual request |
| Author: | vornie [ Thu Jun 12, 2008 1:55 pm ] |
Cheers Doc, looking for as much expertise and tips as poss so we don t damage this beautiful engine |
| Author: | SlantSixDan [ Thu Jun 12, 2008 1:58 pm ] |
You have to work hard to damage a slant-6. |
| Author: | vornie [ Fri Jun 13, 2008 9:00 am ] |
just to let you know we've done it and its working ok, thanks Doc and SSDan for your invaluable advice It s been about five months since we ran the engine - and now there is a tapping noise coming from it - I can t remember if it has always made this noise or it is a new bad noise - any one else ever experience this? Thanks again guys |
