harmonic balancer
https://slantsix.org/forum/viewtopic.php?t=29496
Author:  pinkiedog64 [ Fri Jun 13, 2008 12:38 pm ]
Post subject:  harmonic balancer
What are the guidelines of knowing whether to replace the harmonic balancer or not during a rebuild? Is it a visual test to see if the rubber is in good shape? If so, what is passable, and what is not?
Thanks
Author:  Doc [ Fri Jun 13, 2008 12:45 pm ]
My test.... if it spins straight. if the timing mark is in the correct position and there is no crack along the keyway, i will run it. :twisted:
For units that have a bad groove on the seal surface, I will select a different style seal that rides on a different part of the surface or install a repair sleeve.
