| fuel problem answered https://slantsix.org/forum/viewtopic.php?t=2950 |
| Author: | andrew wagner [ Tue Dec 04, 2001 4:27 pm ] |
| Post subject: | fuel problem answered |
Thank you for all the help and I will put that on my to do list which is very long!! I got the holley blue pump(110gph@ 14psi) in last Friday so I decided to not go to the drags but to put on the pump. To make a long story short the car still ran out of fuel as I shift into third. I did not know why! As I was working today I came up with something, the regulator the came with the pump is preset at 7 psi. So I was wondering if I take the regulator up to 14psi and only turn the pump on after the boost is up. Then with the 8 lbs that I am running I will have 6psi above boost psi which is about where I want it. IT WORKS!!!!!!!!!!! so far, I did not get to a straight back road to stop go thru a full run at it but the car pulled thru third getting onto the highway. It's about time. Since the whether here in pa is great (70 wed.) I was going to try to get to the track on Saturday for test and tune. I will let you know if I go!!!! andrew wagner |
| Author: | Charlie Schmid [ Wed Dec 05, 2001 8:10 am ] |
| Post subject: | Re: fuel problem answered |
Andrew, Get a regulator that has a pressure/vacumm referance port on it. Connect the port to the intake manifold. Then set the regulator at 6 psi, engine running, and as the boost comes up the fuel pressure will stay at 6 psi above boost. Charlie Quote:
: : Thank you for all the help and I will put that : on my to do list which is very long!! I got : the holley blue pump(110gph@ 14psi) in last : Friday so I decided to not go to the drags : but to put on the pump. To make a long story : short the car still ran out of fuel as I : shift into third. I did not know why! As I : was working today I came up with something, : the regulator the came with the pump is : preset at 7 psi. So I was wondering if I : take the regulator up to 14psi and only turn : the pump on after the boost is up. Then with : the 8 lbs that I am running I will have 6psi : above boost psi which is about where I want : it. IT WORKS!!!!!!!!!!! : so far, I did not get to a straight back road : to stop go thru a full run at it but the car : pulled thru third getting onto the highway. : It's about time. Since the whether here in : pa is great (70 wed.) I was going to try to : get to the track on Saturday for test and : tune. I will let you know if I go!!!! : : andrew wagner flturbo6@aol.com |
| Author: | Dave Brode [ Wed Dec 05, 2001 6:39 pm ] |
Andrew/Charlie, In case you don't know, you can make the std Holley <FONT COLOR="0000ff"> reg rise w/boost. Drill/tap the top casting [the part w/the adjustment screw] for 1/8" pipe thread and use a nipple. Run a line to a boost source [manifold]. You must fill the little breather notch in the cover flange [epoxy works well]. This will cause fp to rise with boost. Dave Quote:
: : Get a regulator that has a pressure/vacumm : referance port on it. Connect the port to : the intake manifold. Then set the regulator : at 6 psi, : engine running, and as the boost comes up the : fuel pressure will stay at 6 psi above : boost. : : Charlie dbrode@hereintown.net |
| Author: | andrew wagner [ Thu Dec 06, 2001 12:54 pm ] |
I have ever here that but I do know about the reg. and will do that but this will get through the winter. If it erver gets here!!! andrew wagner Quote:
: Andrew/Charlie, : : In case you don't know, you can make the std : Holley <FONT COLOR="0000ff"> reg rise w/boost. Drill/tap : the top : casting [the part w/the adjustment screw] for : 1/8" pipe thread and use a nipple. Run : a line to a boost source [manifold]. You : must fill the little breather notch in the : cover flange [epoxy works well]. : This will cause fp to rise with boost. : Dave |
