| Custom aluminum radiator arrived—nice! (pics) https://slantsix.org/forum/viewtopic.php?t=29514 |
Page 1 of 2 |
| Author: | SlantSixDan [ Sat Jun 14, 2008 10:30 am ] |
| Post subject: | Custom aluminum radiator arrived—nice! (pics) |
I mentioned some time back in this post that I was having a custom aluminum radiator made by this guy for my '62. (his email was rpettey4@comcast.net at the time I had this rad made, and might still be). It's here, and I'm totally blown away; the craftsmanship is A-number-1. Brackets are accurately and beautifully cut and formed, seams and welds are artful and precise. It weighs almost nothing (see photo for "two finger" liftability). The '60-'62 A-bodies have very limited space at the front of the engine bay, so it's very tough to devise a heavy-duty radiator that'll fit and leave room for the fan. The core of this new rad has a single row of 1" tubes and high fin density. This should give better heat rejection and lower flow resistance compared to the stock radiator (2 rows of 1/2" tubes, low fin density) and the existing recored radiator (3 rows of 3/8" tubes, high fin density): with a conventional radiator, you have multiple dissimilar-material junctions: Coolant to brass tube, brass tube to solder, solder to copper fins, copper fins to paint, paint to air. With the aluminum rad, the junction count is cut significantly: Coolant to aluminum, aluminum to air. I like that this rad is a direct bolt-in and has the factory downflow design so I have similar-to-stock appearance (there's an aluminum theme going on under the hood of this car ) and I needn't rework bracketry and hoses to accommodate a universal crossflow "racing" radiator. It even has a trans fluid cooler. OK, here are the pics. Click any of them to view a larger version in a new window: ![]() ![]() ![]()
| Author: | Joshie225 [ Sat Jun 14, 2008 11:13 am ] |
Very nice. Dare I ask what such a radiator costs? |
| Author: | SlantSixDan [ Sat Jun 14, 2008 11:24 am ] |
'bout $400. |
| Author: | Slant Cecil [ Sat Jun 14, 2008 12:05 pm ] |
I like it. I give it a 6 out of 6 star approval! ![]() I have resisted aluminum rads because of the non OEM appearance of the crossflow design. A coat of semi-gloss black would help with a stealth look. |
| Author: | 64 Convert [ Sat Jun 14, 2008 1:16 pm ] |
Did they have a pattern, or did you have to furnish a stock unit to copy? Has anyone seen a cooling efficiency study between the stock and the aluminum radiator? Since I added AC to my '64 Valiant, it tends to get warm while waiting at a stop light, just when I most need the AC. With no room for a bigger fan or an electric version, I'm convinced an aluminum radiator is the way to go, if there is a big difference in performance. |
| Author: | DusterIdiot [ Sat Jun 14, 2008 1:46 pm ] |
| Post subject: | Are you... |
Quote: With no room for a bigger fan
Are you running a 4 blade stock fan, or one of the optional 7 blade fans found on A/C equipped cars?-D.Idiot |
| Author: | SlantSixDan [ Sat Jun 14, 2008 2:28 pm ] |
Quote: Did they have a pattern, or did you have to furnish a stock unit to copy?
I sent him the radiator I've just posted up in the "Parts For Sale" section.Quote: Has anyone seen a cooling efficiency study between the stock and the aluminum radiator?
I've seen graphs and tables in various SAE papers and such over the years, and they tend to confirm what I was talking about above. But of course the proof will be in the running.Quote: Since I added AC to my '64 Valiant, it tends to get warm while waiting at a stop light, just when I most need the AC. With no room for a bigger fan or an electric version, I'm convinced an aluminum radiator is the way to go, if there is a big difference in performance.
DI's got a very good question about what kind of fan you're running. Remember the Mopar A/C setup included a larger-capacity radiator and a fan shroud, as well as a fan with more blades (6 or 7 depending on year). You've got a lot more room at the front of a '64 than I have at the front of my '62, too.Also remember that recommended practise was (and is) to put the car in Neutral if you're stopped for any extended time with the A/C on, and increase the idle speed slightly with your foot. Increased cooling capacity (fan and/or rad) can help reduce or eliminate the need to do this. |
| Author: | 65 dartman [ Sat Jun 14, 2008 3:50 pm ] |
Quote: Quote: Did they have a pattern, or did you have to furnish a stock unit to copy?
I sent him the radiator I've just posted up in the "Parts For Sale" section. |
| Author: | SlantSixDan [ Sat Jun 14, 2008 4:36 pm ] |
Quote: I wonder if they can duplicate the roundtop tank design?
Nope...this falls under the "try not to let small miracles make you wish for big miracles" category.
| Author: | Jopapa [ Sat Jun 14, 2008 8:58 pm ] |
Very nice. Looks spiffy. Unrelated to the radiator though, I gotta ask: are you rockin' a fro or is there just something on the wall behind your head? |
| Author: | SlantSixDan [ Sat Jun 14, 2008 9:17 pm ] |
Look closer — that's not me in the pic, it's Svensk Slanter. Remember, my beard's longer. |
| Author: | Svensk Slanter [ Sun Jun 15, 2008 4:24 am ] |
I gotta ask: are you rockin' a fro or is there just something on the wall behind your head? *grin* Howdy Slanters! Not quite a 'fro, my wife lovingly refers to this effect as "yid" hair, which dependably occurs when it's time for me to get a haircut. |
| Author: | Jopapa [ Sun Jun 15, 2008 10:10 am ] |
Quote: Look closer — that's not me in the pic, it's Svensk Slanter. Remember, my beard's longer.
LOL, I stand corrected...
| Author: | monkeybusiness [ Sun Jun 15, 2008 3:02 pm ] |
Wow ! thats a nice piece ! how long did it take to have yours made ? |
| Author: | '72Jim [ Sun Jun 15, 2008 8:37 pm ] |
Nice looking piece. it seems the aluminum radiators are the hot setup. Chevelle guys can't wait to spend their money on a new aluminum radiator and electric fan. How do these aluminum pieces hold up to vibration longer-term? I remember my AJS back in the 60s had Al fenders, and wasn't long before cracks appeared at the screw holes. |
| Page 1 of 2 | All times are UTC-07:00 |
