Carb mounting gasket ?
https://slantsix.org/forum/viewtopic.php?t=29518
Page 1 of 1
Author:  00spy [ Sat Jun 14, 2008 11:45 am ]
Post subject:  Carb mounting gasket ?
What is the best carb mounting gasket for the holley 1920.
The carb that I purchased from Dan had the gasket with four holes in the gasket. The ones I have seen online , and that came with the carb kit had one hole and two other slats in it. The one with the four holes is pretty much useless I think because it is blocked off by the intake when put on.
I guess all of the older 1 barrel intakes has the same diameter for the carb. I just don't want to block any passages off if that is possible.
Any answers are appreciated.
Thanks
Dave
Author:  SlantSixDan [ Sat Jun 14, 2008 2:39 pm ]
You need a thick base gasket with two notches. Use a Fel-Pro #60125 or Victor-Reinz #G24105 .
Author:  00spy [ Sat Jun 14, 2008 2:47 pm ]
Thanks Dan,
that is the one I thought
Dave
