| EGR removal https://slantsix.org/forum/viewtopic.php?t=29597 |
| Author: | Royceflo [ Wed Jun 18, 2008 3:25 pm ] |
| Post subject: | EGR removal |
I've read some threads, and service articles regarding removal of the EGR. However before I do this I want to double check. I made a block plate for the egr, manufactured from aluminum and will use a felpro EGR gasket. Im going to remove the "hockey puck" and plug the line into the Intake manifold, as well as into the carb. I'm wondering what exactly to do with the line off the manifold that runs into the "check valve". Can i remove the whole system off of the firewall or should I just plug it with a rubber vacuum plug. Am I missing anything here, or does this all sound okay? |
| Author: | SlantSixDan [ Wed Jun 18, 2008 4:09 pm ] |
Which line with check valve...? |
| Author: | Royceflo [ Wed Jun 18, 2008 5:17 pm ] |
Typo, it runs from the "puck" to the check valve on the firewall, located next to the orifice spark advance control. When I remove the "puck" do I simply plug the nipple on the check valve, or should I remove the whole thing. I don't plan on disposing of any of the pieces, and I don't want to remove anything that I don't need to. |
| Author: | SlantSixDan [ Wed Jun 18, 2008 6:18 pm ] |
You're safe to remove and plug-off all connections that originally went to the puck, the EGR valve, and the thermal vacuum controls in between. Also, bypass the OSAC valve if you haven't already. |
| Author: | Royceflo [ Thu Jun 19, 2008 3:09 pm ] |
I removed the EGR system. All that I took off was the EGR valve, replaced with a new machined piece. Also, the puck with the 4 hoses attached. So that's a total of just two items. Also, I capped the carburetor and intake nipple. Just making sure I got it all. Lastly, I noticed a capped vacuum nipple on the driver side of the carb. Also, on the air-cleaner there are two nipples, one leads right back into the filter, and I know that it has to do with the heated air. The 2nd nipple next to it has no hose. I assume that there is supposed to be a hose running from the driver-side of the carb to the air-cleaner. Any corrections would be appreciated. Thanks again |
| Author: | SlantSixDan [ Thu Jun 19, 2008 3:25 pm ] |
What year is your car, and which carburetor are you running? |
| Author: | Royceflo [ Thu Jun 19, 2008 3:27 pm ] |
1973...it as a holley 1920 on it |
| Author: | SlantSixDan [ Thu Jun 19, 2008 3:55 pm ] |
The capped fitting about 3/4 of the way up the passenger side of the carb is (was) the EGR venturi vacuum tap. Make sure it's capped nice and tightly with no leak. The thermostatic air cleaner hose does need to go to the manifold vacuum fitting on the driver's side. |
