| helppp https://slantsix.org/forum/viewtopic.php?t=29608 |
| Author: | tmj91 [ Thu Jun 19, 2008 4:31 pm ] |
| Post subject: | helppp |
ok ur gunna think im dumb. butt here we go i have a 64 dart with a slant six three on the tree i recently acguired a 318 wideblock with a 727. my question wat will i have to buy to get the 318 onto the three speed? will the slant six bell housing and flywheel work? please help. |
| Author: | slantzilla [ Thu Jun 19, 2008 7:23 pm ] |
Nothing from the Slant will work. |
| Author: | DusterIdiot [ Thu Jun 19, 2008 7:58 pm ] |
| Post subject: | Yep! |
Quote: Nothing from the Slant will work.
And believe me you'll be thankful for it!Quote: i recently acguired a 318 wideblock with a 727.
my question wat will i have to buy to get the 318 onto the three speed? will the slant six bell housing and flywheel work? I hope your cutting torch and welding skills are up to par, because you'r gonna be using them... (that and a showhorn, pry bar... and the costco size bucket of KY to force that fat block into the narrow engine bay)... The 318 poly uses many of the parts the 1967 LA block 318 uses ... but its a bit bigger and heavier, and it doesn't have as many easy to get parts... Now for the cost of your conversion you could get a gas mileage getting performance slant that will probably equal that 318... -D.Idiot |
| Author: | Doc [ Fri Jun 20, 2008 10:34 am ] |
I think exhaust manifolds (or lack of any that fit this application) is the "show stopping" issue to overcome. DD |
| Author: | tmj91 [ Sat Jun 21, 2008 2:08 pm ] |
will the bell housing not bolt up eitherE? |
| Author: | gmader [ Sat Jun 21, 2008 2:39 pm ] |
Nope, the bellhousings and proposed motors are different. |
| Author: | DusterIdiot [ Sat Jun 21, 2008 6:15 pm ] |
| Post subject: | Your mopar tranny pattern lesson... |
Like all auto manufacturers bellhousings usually are grouped by an engine type/family/application... Mopar kept things real simple: slant-6 only A/LA Engine (318 poly, and all 273-360-5.9 Magnum engines) Big Block (350-440) (and later the Jeep 4.0L-AMC I-6 family) You will have to have an adaptor to go from one to the other, or the proper tranny... the slant six tranny (if an auto) would not like the brutal abuse the 318 would put on it anyway. -D.Idiot |
| Author: | slantzilla [ Sat Jun 21, 2008 7:24 pm ] |
| Post subject: | Re: Your mopar tranny pattern lesson... |
Quote: Mopar kept things real simple: slant-6 only A/LA Engine (318 poly, and all 273-360-5.9 Magnum engines) Big Block (350-440) (and later the Jeep 4.0L-AMC I-6 family) -D.Idiot 4 cyl. Nova motor, straight and V-6 cylinder, small block, pig block. Same bolt pattern. |
| Author: | DusterIdiot [ Sat Jun 21, 2008 7:32 pm ] |
| Post subject: | Lol... |
Quote: Mopar is actually a nightmare compared to Chevy.
But definately much nicer than Ford! (Lemme see... the 351C is a small block, but the extended deck 400C only bolts to the 429/460 pig block tranny... and which pig block is it 427/428 or a 429/460?) -D.Idiot |
| Author: | Charrlie_S [ Sat Jun 21, 2008 9:06 pm ] |
| Post subject: | Re: Lol... |
| Author: | RamSST [ Sat Jun 21, 2008 11:24 pm ] |
Isn't the 318 wideblock also supposed to take the chrysler firepower hemi heads? If so I'd grab some of those parts and make that 318 poly a decent motor instead of an iron lung. |
| Author: | slantzilla [ Sun Jun 22, 2008 12:30 am ] |
Quote: Quote: Quote: Mopar is actually a nightmare compared to Chevy.
But definately much nicer than Ford! (Lemme see... the 351C is a small block, but the extended deck 400C only bolts to the 429/460 pig block tranny... and which pig block is it 427/428 or a 429/460?) -D.Idiot 221,260 and 4 bolt 289 go together. 5 bolt is the same as 302/351 C&W. 331,352,360,390,406,427, and 428 were the same. 351-M/400, 429, and 460. Easy as cake, right? Unless you want to get into all the different Mercury/Lincoln/truck ones too. |
