Spark plug tubes
https://slantsix.org/forum/viewtopic.php?t=29639
Author:  pinkiedog64 [ Sat Jun 21, 2008 10:33 pm ]
Post subject:  Spark plug tubes
Should I get new spark plug tubes and seals (are there seals that go there?) for my slant? I've crossed the 1/2 way point on the rebuild. I'm starting to put stuff back together with all the new parts and was wondering about the plug tubes.
If so, where do I get them? It's for a '64 225
Author:  emsvitil [ Sun Jun 22, 2008 2:43 am ]
Inspect the tubes, the should be fine.
But get new seals.
Author:  Charrlie_S [ Sun Jun 22, 2008 5:11 am ]
Tube seals will be in the gasket set. They are the "square" cut "O" rings.
Author:  pinkiedog64 [ Sun Jun 22, 2008 8:25 am ]
Ok, thanks. Dumb question, but where do the seals go-between the plug and the tube or between the tube and the block? My engine didn't have any when I pulled them out-guess it's a good thing I'm putting them in. I'll look at the gasket set today and see if I can see where they go.
Author:  dakight [ Sun Jun 22, 2008 8:31 am ]
They slip over the tube and form a seal between the lip of the tube and the block. (cylinder head)
Author:  SlantSixDan [ Sun Jun 22, 2008 9:36 am ]
Don't forget to remove the metal ring washers from the spark plugs before installing them -- they're not used on '63-'74 slant-6 heads.
Author:  emsvitil [ Sun Jun 22, 2008 4:37 pm ]
The old tube seals may have stuck to the head rather than the tube.........
Author:  Fefferman [ Sat Jul 12, 2008 12:02 am ]
What would happen if you didn't remove the washer from the spark plugs on a 70 198 /6? I just bought one and am having trouble getting it to start. I know I have some carb issues, but just caught this thread and wondered if this may be aggravating the situation. Thanks!!
Author:  SlantSixDan [ Sat Jul 12, 2008 9:02 am ]
The presence of the plug washers probably isn't affecting the engine's ability to start. Tune-up parts and technique suggestions are in this thread. If you'll post a new topic here in the Engine forum detailing the problem you're having and what you've tried so far, we can help you get it solved.
