| What do you think of these wheels? https://slantsix.org/forum/viewtopic.php?t=29646 |
| Author: | Joshie225 [ Sun Jun 22, 2008 9:47 am ] |
| Post subject: | What do you think of these wheels? |
I like this wheel, but still may hold out for Torq-Thrust® II Classic Custom Offset, but they are significantly more expensive. I need to call and see if the center bore is compatible with our cars and it appears the existing center cap would not fit the front. The up side is that the 17x8" +15mm should fit the front of an A-body fine and only need a 1/4 or 3/8" spacer in the rear. The wheels are about $150 each. I'm curious as to where they are manufactured too. ![]() The twice as expensive, but better looking option.
