Draining battery
https://slantsix.org/forum/viewtopic.php?t=29706
Author:  keoki_d [ Tue Jun 24, 2008 10:38 pm ]
Post subject:  Draining battery
i changed the alternator, voltage regulator, tested the battery, disconnected my sound system and my battery keeps draining every week. i recharge it, test it, its good for a week then dies. Battery always tests good (per Auto Zone) and i dont know what else it could be.......is there anything else i need to check?
Author:  emsvitil [ Wed Jun 25, 2008 12:09 am ]
Disconnect everything, and see what happens.
Author:  THOR [ Wed Jun 25, 2008 12:21 am ]
I had that same problem on a different vehicle I used to own....
Does your horn work properly?
The last instance I worked on, the horn relay buggered out, and stayed activated, draining the battery within about a week or so.
Good luck! 8)
Author:  keoki_d [ Wed Jun 25, 2008 4:05 pm ]
Good luck! 8)
yeah, my horn works there is a loose wire in there and once in a while it'll touch and my horn will start sounding on its own.......
