| Heat riser box https://slantsix.org/forum/viewtopic.php?t=29798 |
| Author: | Russ [ Sun Jun 29, 2008 4:42 pm ] |
| Post subject: | Heat riser box |
Hello, While redoing the intake/exhaust studs, gaskets and so on, I have come to the conclusion that the heat riser box which installs beneath the manifolds, is not worthy of re-installation. ( That it didn't fall off is surprising ) Any thoughts on where one of these might be procured? Thank-you |
| Author: | SlantSixDan [ Sun Jun 29, 2008 4:45 pm ] |
The heat riser valve is built into the exhaust manifold. Which part, exactly, are you referring to as a separate piece? |
| Author: | Russ [ Sun Jun 29, 2008 5:24 pm ] |
Hi The piece I speak of is a metal shroud that bolts with two fasteners and then an aluminum hose attaches to this and provides heat up to the carb. Its construction appears to be light sheetmetal |
| Author: | Aggressive Ted [ Sun Jun 29, 2008 5:27 pm ] |
It helps on cold start ups, and is especially handy on very cold winter days. The aluminum hose hooks to it and is routed up to your snorkel inlet. I run mine religiously! |
| Author: | SlantSixDan [ Sun Jun 29, 2008 5:50 pm ] |
Ah, that's not part of the heat riser. It's the thermostatic air cleaner heat stove. They go by on eBay from time to time, though I don't see any at the moment. They're all the same from '70 (first year) through '87 (last year). Definitely worth having, as Ted says. |
| Author: | DusterIdiot [ Sun Jun 29, 2008 7:20 pm ] |
| Post subject: | Lol... |
I have a few laying around... if you need another one shoot me a PM... -D.Idiot |
| Author: | ESP47 [ Mon Jun 30, 2008 9:44 pm ] |
Doesn't that piece have a bracket on it which is used for the kickdown linkage? |
| Author: | DusterIdiot [ Mon Jun 30, 2008 9:45 pm ] |
| Post subject: | No... |
Quote: Doesn't that piece have a bracket on it which is used for the kickdown linkage?
The bracket is bolted to the manifold bolts, the heat stove bolts to it with a couple of shorty bolts...-D.Idiot |
| Author: | THOR [ Mon Jun 30, 2008 10:21 pm ] |
I've also got a few.... if anyone else needs one. ~THOR~ |
