Drive belt setup
https://slantsix.org/forum/viewtopic.php?t=29849
Author:  trdrew [ Thu Jul 03, 2008 9:57 am ]
Post subject:  Drive belt setup
I'm using a slant in a period style hot rod and will not be running A/C or power steering. What belts/routing should I use?
Author:  SlantSixDan [ Thu Jul 03, 2008 10:19 am ]
Depends on which alternator you'll be running, whether you'll be mounting it on the manifold side or distributor side of the engine, and which-year brackets you'll be using to do so.
Author:  trdrew [ Thu Jul 03, 2008 10:42 am ]
Thanks, Dan. Slant is out of a '74 Dart. I'd like to use the stock alternator & mounting bracket on the distributor side of the block.
Author:  slantzilla [ Thu Jul 03, 2008 10:46 am ]
The extra pulleys will unbolt off the damper and you can run 1 belt for the water pump and alternator. :D
Author:  SlantSixDan [ Thu Jul 03, 2008 11:05 am ]
Yep, just use the stock fan/alternator belt for a '74 Dart. If the car had P/S, A/C, or an air injection ("smog") pump, the extra pulleys can simply be unbolted from the front and/or rear of the combination crank pulley/vibration damper.
Author:  trdrew [ Thu Jul 03, 2008 1:39 pm ]
Thanks guys, much appreciated.
