It is currently Sat Jun 06, 2026 6:40 am
 Post subject: Drive belt setup
PostPosted: Thu Jul 03, 2008 9:57 am
I'm using a slant in a period style hot rod and will not be running A/C or power steering. What belts/routing should I use?
PostPosted: Thu Jul 03, 2008 10:19 am
Depends on which alternator you'll be running, whether you'll be mounting it on the manifold side or distributor side of the engine, and which-year brackets you'll be using to do so.
PostPosted: Thu Jul 03, 2008 10:42 am
Thanks, Dan. Slant is out of a '74 Dart. I'd like to use the stock alternator & mounting bracket on the distributor side of the block.
PostPosted: Thu Jul 03, 2008 10:46 am
The extra pulleys will unbolt off the damper and you can run 1 belt for the water pump and alternator. :D
PostPosted: Thu Jul 03, 2008 11:05 am
Yep, just use the stock fan/alternator belt for a '74 Dart. If the car had P/S, A/C, or an air injection ("smog") pump, the extra pulleys can simply be unbolted from the front and/or rear of the combination crank pulley/vibration damper.
PostPosted: Thu Jul 03, 2008 1:39 pm
Thanks guys, much appreciated.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 6 guests
