do 727s have a vacum line?
https://slantsix.org/forum/viewtopic.php?t=29875
Page 1 of 1
Author:  illldeca [ Sat Jul 05, 2008 1:11 pm ]
Post subject:  do 727s have a vacum line?
thats needs to hook up in order for them to work right cuz my tranny on my truck is not working and only reverse is working it kicks foward when i hit the gas lucklly i got anther transmission in the back of my truck
Author:  Joshie225 [ Sat Jul 05, 2008 1:14 pm ]
Nope. Chrysler uses a throttle pressure linkage rather than a vacuum modulator.
Author:  illldeca [ Sat Jul 05, 2008 1:17 pm ]
so im guesing the trannys blown
Author:  Joshie225 [ Sat Jul 05, 2008 1:50 pm ]
If the truck moves forward when the throttle is opened and the fluid is full (checked idling in neutral) then yes, you likely have internal problems.
Author:  illldeca [ Sat Jul 05, 2008 2:38 pm ]
it doesn't really move it jolts foward but doesnt really go any where :? the fluid is fine the plan looks like it has some dents coming from the inside :( the other tranny i have is from a marauder that had a slant 6 it seems shorter you think the swap is do able onto my d150 truck ?
Author:  illldeca [ Sat Jul 05, 2008 2:56 pm ]
it looks like the same transmission i think its a 727 aswell i took off the pan it seemed like there were no visable internal problems its pretty dry though and needs a new filter
