will 73-75 fury wagon disc brakes work on my 73 dart swinger
https://slantsix.org/forum/viewtopic.php?t=29942
Page 1 of 1
Author:  runyonracing [ Thu Jul 10, 2008 2:59 pm ]
Post subject:  will 73-75 fury wagon disc brakes work on my 73 dart swinger
i have a set of fury wagon disc brakes off a 73-75 era and was wondering if theyd work on my 73 dart swinger. can someone help
thanks
Author:  Joshie225 [ Thu Jul 10, 2008 4:07 pm ]
Not if it's a C-body. B-body stuff will bolt on, but C-bodies are different. The later '75 and newer small Fury is a B-body, but the older ones are C-bodies. The C-body year break is '73 if memory serves so if you have the 1973 only disc brakes you can sell them for decent money to a C-body fan that want to upgrade.
Author:  runyonracing [ Thu Jul 10, 2008 5:55 pm ]
thanks for the help
Author:  Middy [ Tue Jul 15, 2008 1:22 pm ]
Post subject:  Re: will 73-75 fury wagon disc brakes work on my 73 dart swi
thanks
Would you be interested in selling your C-body brakes?
Author:  MoJoe [ Tue Jul 22, 2008 1:09 pm ]
I used c-body rotors and caliper brackets on my a-body disc brake spindles it works great. This way you can utilize the larger rotors of the big cars. I believe you could have either slider type calipers or the style that slide on pins like in early E-bodies which is what I chose. Mopar Action did a story on this with pictures of the parts for identification. Check out their website it is in the tech archives.
Author:  andyf [ Tue Jul 22, 2008 10:27 pm ]
The only way to use C body rotors on A body spindles is if you had a set of custom wheel bearings made.
Author:  Joshie225 [ Tue Jul 22, 2008 10:51 pm ]
Andy is right. The car your parts came from was not a C-body. Plenty of B-bodies were given names formerly used on C-bodies.
Author:  andyf [ Wed Jul 23, 2008 7:40 am ]
I have thought about having a custom wheel bearing made for this application since it would allow a C to A swap. It is a simple change to the bearing, basically it just needs a slightly different OD. With the conversion bearing a person would be able to slide the 11.75 x 1.250 C body rotor onto any A,B or E body knuckle.
The main reason I'd do that is that then my Viper kit would be a better bolt on kit and the pad spacers could be elminated. The Viper caliper is designed for a 1.250 rotor rather than the 1.00 thick rotor that came on the big B body cars.
Author:  MoJoe [ Wed Jul 23, 2008 1:02 pm ]
You are correct, I got the parts from a B-body with a C-body name, sorry about that. Here is the M.A. link I was talking about.
Author:  MoJoe [ Wed Jul 23, 2008 1:03 pm ]
http://www.moparaction.com/Tech/archive/disc-main.html
Author:  MichaelS [ Wed Jul 23, 2008 1:59 pm ]
A body B, C, what body is the '72 Charger? And will any parts off of one fit a '74 Dart? I have one that is beyond repair and my Dart is willing to accept any upgraded part swap.
Author:  Joshie225 [ Wed Jul 23, 2008 3:30 pm ]
Chargers are B-bodies. Those spindles and rotors are different than the '73 and later ones. Probably best to sell those to someone that wants older B-body disc brakes and find the correct stuff for the Dart.
Author:  andyf [ Wed Jul 23, 2008 6:46 pm ]
'72 Charger stuff will bolt onto an A body (need big ubj) but the rotors are expensive if you can even find them. Most people use the '73 or newer stuff because it is dirt cheap.
