| Wiring From Newer Turn Signal Switch And A Different Harness https://slantsix.org/forum/viewtopic.php?t=29979 |
| Author: | johnwhitty [ Sun Jul 13, 2008 2:56 am ] |
| Post subject: | Wiring From Newer Turn Signal Switch And A Different Harness |
Hi. I have installed a 1966 turn signal switch in my 1963 valiant. The harness' are different so I have clipped all the wires. I have matched the colors and have 2 tan wires connecting to a single tan one and 2 light green wires connecting to a single of the same color also. The others are red/red, white/white, etc... My signals are not working correctly. My brake lights don't work. I am frustrated as I have downloaded wiring diagrams and they seem to logically match up. Does anyone have any advice? Am I being an idiot, cuz I sure feel like one? Thanks very much. John. |
| Author: | SlantSixDan [ Sun Jul 13, 2008 5:05 am ] |
Actually...the only difference between a '63 turn signal switch and a '66 turn signal switch would be the terminals at the ends of the wires. Same number and colours of wire, but the '62-'63 cars used 1/4" blade connectors, and the '64+ cars used tang-and-box connectors. The wiring itself is the same. I wonder if what you think is a '66 A-body switch might in fact be something different. Where did you get the "new" switch? |
| Author: | johnwhitty [ Sun Jul 13, 2008 11:10 am ] |
| Post subject: | wiring on a '63 signet |
Thanks for your reply. It seems to me that they are exactly the same. I took the wiring out of a '66 steering column. The wires are tan, brown, red, black, white, light green, and dark green. The lt grn and tan are 2 each from the column going into one wire. These are the front and rear signals. The thing is I don't know if I am connecting them properly. Both rear signals light up and only the front right. The left front will only when I play around w/ the connections. I am just wondering what the hell I'm doing wrong and feeling frustrated and stupid. Anyway, if you have any more info let me know. Thanks for responding. John. |
| Author: | SlantSixDan [ Sun Jul 13, 2008 12:27 pm ] |
1. A '66 steering column from what model? 2. Was this '66 turn signal switch known to work correctly in the car it was originally installed in...? |
| Author: | Doc [ Mon Jul 14, 2008 12:26 pm ] |
It is hard to find a "good" used turn signal switch. You problem is likely in the switch itself. How did you re-connect the cut wires? DD |
| Author: | johnwhitty [ Wed Jul 16, 2008 11:51 pm ] |
| Post subject: | signet 200 wiring |
it is off a 66' valiant and i believe it worked. i guess it could be faulty wiring. My car's wiring was working before and I just needed a switch that had good springs. ???? |
| Author: | VDART [ Sun Jul 20, 2008 5:32 am ] |
| Post subject: | t-signal switch |
did you get this fixed? doulble check your connections---- hopefully your used harness was at least as good as the original. Lawrence |
