It is currently Thu Nov 26, 2026 3:22 pm
PostPosted: Fri Jul 18, 2008 8:34 am
Does Tire Size Effect Alignment Specs?
I am just speaking of size, not Type or construction. Sticking with modern steel belted radials here.
For example if I take a car to the Shop to get aligned it up. Say I had 4 195-75-14's on there, got it Lined up, and I swapped them out later to 225-70-14's ?
Would swapping the tires be cause for me to take it back in again??
PostPosted: Fri Jul 18, 2008 8:47 am
Greg,
You would have to put a significantly larger or smaller tire diameter on one end of the car to change the caster. The camber and toe would stay the same. The 225/70R14 is 0.9" taller than the 195/75R14 and would only change the ride height 0.45" which is negligible so no worries about the alignment. Also, if you have a 7" wide wheel you could go 235/60R14 which is only .4" shorter than the 195/75R14.
PostPosted: Fri Jul 18, 2008 2:07 pm
Josh,
I need to put some tires on my 1972 Duster and I was wondering what size looks right. I have 7" wide 15" Rallyes with a disk brake front end. The rear tires are 255 60R 15's on 8" Rallyes.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Fri Jul 18, 2008 2:42 pm
You should be able to do 215/60R15s pretty easily, maybe 225s, but anything bigger probably won't fit without rubbing or fender trimming.
This car has 205/60R15s on the front 235/60R15 on the back. I don't like putting too wide a tire on a given wheel as they wear and handle poorly.
Users browsing this forum: Ahrefs [Bot] and 6 guests
