225 Knocking
https://slantsix.org/forum/viewtopic.php?t=30024
Author:  shane.colston [ Tue Jul 15, 2008 9:24 pm ]
Post subject:  225 Knocking
84k origanal on 225 automatic in a 73 dart sport. All rockers adj correctly .10 and .20. Taken pan down removed 4 and 5 rod caps, normal breakdown. Noise still rear of engine inside block. Rev up and as rpm lowers nockinf is louder then normal tick, it always the lowdest after reving.
Author:  Fopar [ Tue Jul 15, 2008 10:04 pm ]
you might check the convertor bolts
Author:  Doc [ Wed Jul 16, 2008 8:41 am ]
Worn-piston pin or a collapsed piston?
Author:  MilwaukeeTech [ Thu Jul 17, 2008 3:35 pm ]
Did that vehicle use a flex plate? Old Fords knock like crazy with a cracked flex plate, and it's sometimes difficult to tell the difference between that and a rod knock.
Author:  Bren67Cuda904 [ Thu Jul 17, 2008 4:13 pm ]
I 2nd that
