It is currently Sun Nov 29, 2026 10:20 am
PostPosted: Tue Jul 15, 2008 7:20 pm
What's all involved in changing the Gear selector / Throttle Pressure/Kickdown Lever Seal??
I have replaced the pan and pan seal with new stuff. and I still get a nasty Drip.
I think it's the Kick down seal.
Can this be replaced while the trans is still in the truck??
PostPosted: Tue Jul 15, 2008 7:34 pm
It can be done with the trans in the vehicle. It is much easier if you remove the valve body, but it can be done without removing it.
