| Ammeter Pinned https://slantsix.org/forum/viewtopic.php?t=30046 |
| Author: | polara pat [ Thu Jul 17, 2008 12:20 pm ] |
| Post subject: | Ammeter Pinned |
This is a brand new problem that started today. My factory ammeter has always worked perfectly (as do all my other guages) but today with any sort of throttle, the needle would peg to "C". If I let off then it would go just between mid way and "C". I thought I could smell a slight electrical burn but I may have imagined that. I run a Mopar EI with a black box. I believe my alternator has a built in regulator. The other thing I noticed is that when I did an under hood inspection, I found the alternator to be really hot to the touch. Any insight would be appreciated, I can't afford to have any down time with the little wagon. Thanks, Pat |
| Author: | SlantSixDan [ Thu Jul 17, 2008 12:26 pm ] |
Your voltage regulator is faulty. Stop running the car at once until this is fixed, or you'll do extensive damage to the car's electrical system. Mopar charging systems, as far back as infinity and as recently as this year, do not use internally-regulated alternators. If yours has an internal regulator, it's something significantly different than stock and you'll need to describe it in detail. |
| Author: | polara pat [ Thu Jul 17, 2008 12:34 pm ] |
Quote: Your voltage regulator is faulty. Stop running the car at once until this is fixed, or you'll do extensive damage to the car's electrical system.
Sorry, not knowing the exact details of my alternator pressured me into a guess, I'm O.K. now. I'll replace the VR immediately and see if my problem improves. Stay tuned.
| Author: | polara pat [ Thu Jul 17, 2008 1:05 pm ] |
New regulator installed and behaving as it should. Quick fix...it's my favorite kind of fix. Let's hope there was no unseen damage caused by the drive home with the faulty regulator. |
| Author: | SlantSixDan [ Thu Jul 17, 2008 1:13 pm ] |
One way I've seen this failure precipitated is by loss of regulator ground. Run a good ground loop (14ga wire ought to be plenty) from the battery negative terminal to the regulator base, and from the regulator base to the alternator housing. Many alternators have a "GRD" hole in the rear half of the housing; use a short self-tapping screw to secure the wire to this hole (short so that the screw doesn't protrude too far into the alternator and cause damage). If no GRD hole on your alternator, secure the wire to one of the three through-bolts with a ring terminal. |
| Author: | polara pat [ Thu Jul 17, 2008 1:20 pm ] |
Sound advice. What are the part #s again for the non-Chinese VR's? I know my local shop stocks Ecklin and Blue Streak. |
| Author: | SlantSixDan [ Thu Jul 17, 2008 1:39 pm ] |
Blue Streak VR-128, Echlin VR-1001. |
