Ball Joint Socket Size
https://slantsix.org/forum/viewtopic.php?t=30064
Author:  60 Pioneer [ Fri Jul 18, 2008 9:08 am ]
Post subject:  Ball Joint Socket Size
Does anybody know which socket size I will need for removing the ball joints on a 1960 Dodge?
It appears that Chrysler used 2 different sizes over the years...1 59/64" and 2 9/64". At $40 a pop, I want to make sure that I get the right one.
Thanks All
Author:  Sam Powell [ Sun Jul 20, 2008 9:53 am ]
That is a special socket. Can you measure the ball joint? The smaller one fits the A body cars up until 1972, but I don;t know if your Dart is an A body car, or the larger B body. I suspect it is the larger size, but I would not want to be the one to mis-inform you, and I dont; know for certain. Why not just measure the ball joint?
Sam
Author:  70valiant [ Sun Jul 20, 2008 1:54 pm ]
I just did mine on my 66, I rented a kit from Advanced Auto. The kit had two sizes and I needed the smaller one, but I cant remember the size.
Author:  volaredon [ Sun Jul 20, 2008 2:45 pm ]
Actually I believe there are 3 different sizes; its been a while since I have seen aSnap on catalog; I have 2 of them; the one Im missing is the early A. I've never ever needed that one though. the smaller of the 2 I've got has done most Mopar cars Ive had to work on, (lots of "late-B", F-J-M bodies) the larger one I've used a bunch on trucks/vans; I think that the truck one also applies to C bodies.
Author:  60 Pioneer [ Mon Jul 21, 2008 6:10 am ]
Thanks for all of your replies.
I wasn't sure where to measured on the the ball joint. I assume across the flat sides. My measurement came out on the high side of 1 7/8", so I suspect that it is the 1 59/64" socket that is required.
Thanks for the tip on Advance Auto.
Author:  70valiant [ Mon Jul 21, 2008 1:17 pm ]
It's not a true rental, you pay for the kit(it was like $180) and then they refund ALL your money back when you return the kit.
Author:  ESP47 [ Tue Aug 05, 2008 5:09 pm ]
I took the upper control arm off, flipped it over and put the ball joint in a vice. Then I stuck a pipe through the control arm holes and turned the entire arm. Used a pipe wrench to put the new ball joint in.
Author:  70valiant [ Tue Aug 05, 2008 5:42 pm ]
Now thats clever, pat on the back from over here.
