| engine STILL running rough https://slantsix.org/forum/viewtopic.php?t=3007 |
| Author: | Larry [ Sat Dec 15, 2001 5:04 pm ] |
| Post subject: | engine STILL running rough |
ok, i adjusted the valves today at .10 for intake and .20 for exhaust, it cleared up some of the shaking, but it is still there. any other things i should check? I checked the cap and rotor and they look good, i also checked the carb, looks good, the timing seems to be off, i was fooling with it and it showed a little improvement. what is the recommended timing? sorry for all the questions but it's got me baffled about what is making it shake and not be smooth. ksjo923@Hotmail.com |
| Author: | snarl [ Sun Dec 16, 2001 2:04 pm ] |
| Post subject: | Re: engine STILL running rough |
: ok, i adjusted the valves today at .10 for : intake and .20 for exhaust, it cleared up : some of the shaking, but it is still there. : any other things i should check? I checked : the cap and rotor and they look good, i also : checked the carb, looks good, the timing : seems to be off, i was fooling with it and : it showed a little improvement. what is the : recommended timing? sorry for all the : questions but it's got me baffled about what : is making it shake and not be smooth. Check the sparkplugs. They might be slightly fouled out and not firing correctly causeing the shaking. snarl@net-change.com |
| Author: | Gary [ Sun Dec 16, 2001 3:46 pm ] |
Larry, check the point where your PCV hose enters the manifold. I have seen the passage plugged with carbon in that area, and it will cause the engine to run rough. lancer_41@excite.com |
| Author: | Larry [ Sun Dec 16, 2001 4:37 pm ] |
: Larry, check the point where your PCV hose : enters the manifold. I have seen the passage : plugged with carbon in that area, and it : will cause the engine to run rough. i don't have a PCV that goes into the manifold. i have one that goes to the valve cover did you mean that one? |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Dec 16, 2001 5:15 pm ] |
: ok, i adjusted the valves today at .10 for : intake and .20 for exhaust, it cleared up : some of the shaking, but it is still there. : any other things i should check? I checked : the cap and rotor and they look good, i also : checked the carb, looks good, the timing : seems to be off, i was fooling with it and : it showed a little improvement. what is the : recommended timing? sorry for all the : questions but it's got me baffled about what : is making it shake and not be smooth. Have you run a compression test? What are the cranking compression readings, cylinder by cylinder? Any low reading cylinders? It could be a burned valve or bad rings. DD |
| Author: | Gary [ Sun Dec 16, 2001 6:31 pm ] |
The other end of the hose goes to either the base of the carb or to a plate between the carb and the manifold. That's where it will plug. For a quick check, pull the hose off the PCV valve and see if you can blow through it. lancer_41@excite.com |
| Author: | Larry [ Sun Dec 16, 2001 8:10 pm ] |
: Have you run a compression test? What are the : cranking compression readings, cylinder by : cylinder? Any low reading cylinders? It : could be a burned valve or bad rings. : DD I don't have a compression tester. guess i should ask for one for Christmas! |
| Author: | mike [ Mon Dec 17, 2001 8:06 am ] |
: Check the sparkplugs. They might be slightly : fouled out and not firing correctly causing : the shaking. sounds like vacuum get caps a plug up the line that goes to your vacuum booster for your brakes if it smoothes out the rubber membrane in vacuum booster unit is out. had same problem scooterthedog@hotmail.com |
