It is currently Sun Oct 11, 2026 3:52 pm
PostPosted: Sat Jul 26, 2008 11:08 pm
Car Model: 1964 Valiant V200
Crazy - while giving the valiant a tuneup I put on a new cap and rotor (rotor was old stock, came with the car). Got a ticking sound, investigated and found it was the rotor hitting the cap.
Tried a different rotor I had and 'crack' stripped distributor gear. At least I had a spare distributor laying around that I could rob the gear from to get it going again.
Anyone seen this? Cap is a good one - Echlin that the NAPA guy said was better than others. Guess it's another sign of the crap quality of most aftermarket parts these days.
PostPosted: Sat Jul 26, 2008 11:12 pm
Actually, the Echlin cap is the troubled one that's usually ground off-center. Take a look at the posts inside the cap and see if they are all ground equally.
PostPosted: Sat Jul 26, 2008 11:39 pm
Not very - that's clearly the problem.
I just read some other posts on this issue from Dan, so now time to get another cap.
PostPosted: Sun Jul 27, 2008 7:46 am
Damn...they're still grinding the Echlin MO-40/MO-4000 caps off centre?! I first saw this problem in 1993! Get a Standard-BlueStreak CH-410X cap instead.
Users browsing this forum: Bing [Bot] and 16 guests
