| Width of an A-body sway bar? https://slantsix.org/forum/viewtopic.php?t=30131 |
| Author: | NewSlanter [ Mon Jul 21, 2008 10:33 pm ] |
| Post subject: | Width of an A-body sway bar? |
What is the eye-to-eye width of a sway bar to fit a 1970 dart? I have one with mounts that line up perfectly with the holes on the K-member, but the ends seem too far outboard to line up with the tabs on my LCAs. Does anyone have the measurement? Maybe a picture of a bar installed on a 1970 vintage Dart? Thanks in advance, Nat |
| Author: | Jim Lusk [ Fri Aug 15, 2008 3:10 pm ] |
You may have a b-body bar, but are you measuring the distance between LCA tabs with the weight of the car on the LCAs? The tabs get a lot closer with the suspension dangling. |
| Author: | NewSlanter [ Fri Aug 15, 2008 8:59 pm ] |
Thanks for your reply. It is from a 1970 Dart. Problem is, the LCAs are out of a 1975, so the sway bar tabs are in the wrong spot. I'm going to have them cut off and welded back in the proper spot for my 1970 sway bar. I'll probably have the LCA reinforced while I'm at it. Thanks again, Nat |
| Author: | Rug_Trucker [ Wed Aug 20, 2008 7:17 am ] |
Did'nt the newer ones use a different bar? I have one hanging in the shop. What year I have no clue! |
| Author: | Jim Lusk [ Wed Aug 20, 2008 8:11 am ] |
Yes, 73-76 used a narrower bar that ran through the k-member. |
