It is currently Fri Oct 09, 2026 5:23 am
 Post subject: carbs
PostPosted: Wed Jul 23, 2008 5:26 pm
what was the best 1 bbl used on a slant six for performance till i can get a 4 bbl
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Wed Jul 23, 2008 5:48 pm
probably the one you got, unless its a 1945.
you dont want to slap a four-barrel on there anyway until youve done up the cylinder head.
PostPosted: Wed Jul 23, 2008 7:39 pm
A Holley 1920 Economaster can give great mileage and still provide some good tire spinning pep! :D
It is super easy to tune and to change the jet.
SL6Dan has a few new ones for sale.
PostPosted: Thu Jul 24, 2008 12:05 am
I have that same carb and i can NEVER get the tires spinning...on dry weather. Please elaborate as i wish to "light 'em up"
71 dodge dart custom
1988 Honda Civic ((Because racecar))
2005 VW Jetta
1963 AMC Rambler American 440
PostPosted: Thu Jul 24, 2008 5:32 am
well that takes the fun out of every thing dont it i got the 1920 holly but where would you get jets for it for performance tuning
and i will have the head hopped up with 3 angle valve grind ported and pollished oversize valves with the 4bb eventully
Last edited by theslantingsix on Thu Jul 24, 2008 5:36 am, edited 1 time in total.
 Post subject: Parts store or...
PostPosted: Thu Jul 24, 2008 5:34 am
You can get them at a parts store, or a speed shop...
They are the same as any Holley 4 barrel...
PostPosted: Thu Jul 24, 2008 5:37 am
sweet power here we come
enny recomended jet sizes
PostPosted: Thu Jul 24, 2008 11:30 am
Gents,
On jet sizes, anything after a #57 will get the tires spinning with the Econmaster. I have a 8 3/4, 2.76 posi-traction rear end with 14" P235 60R Grand Am's made by Goodyear for Les Schwab.
The 1920 Holley Economaster has a dual plunger power valve which dumps allot of fuel when you punch it. If you jet up to a #59 or 60 it is very punchy. Going larger, up to a 62 or 64 makes it alot of fun but mileage drops down accordingly. With a 62 it dropped down to 22 mpg because I was having too much fun!
Since I am driving lots of miles, 130 a day minimum, I put the #57 back in so I can get 24 mpg average for combined stop and go and freeway. It is still very peppy and I can bust them loose now and then on dry pavement. Lately I have been concentrating on trying to get better mileage and keeping it under 70 mph.
On engines that are fairly new but are sluggish, do the distributor recurve and valve lash. On my cam I set them at .012 and .022 for a little more seat time and torque per Doc's recommendation. On the recurve I am at 32 degrees by 2500 rpm, (initial is at 16 degrees with 16 degrees mechanical). That will help wake up your engine. :D
For those build new engines for mileage, be sure to advance the cam 4 to 6 degrees. Doc had me do that to help low end torque to pull the taller tires and higher rear end ratio.
PostPosted: Thu Jul 24, 2008 1:29 pm
i might play with that alot and and put in 64's and just till i get the 4bbl and then have it running good with econimy
PostPosted: Thu Jul 24, 2008 2:29 pm
Do you already have the 4 barrel?
Which one are you planning on using?
A 500 cfm 2 barrel would also work well.
PostPosted: Thu Jul 24, 2008 3:52 pm
well i got a super six manifold but i just dont want to put the money into a two bbl if the money is going to be waisted when i get the 4 bbl so i am just trying to spend my money wisely till i get a good job
PostPosted: Thu Jul 24, 2008 5:11 pm
I was thinking the same thing after I bought the super six setup. So I bought a 4 barrel manifold to run the two barrel on, either Holley or Barry Grant 500 cfm. That way I can go either way, two or four barrel.
Right now I am fine tuning the one barrel just to see what it will do.
My friend loves his 4 barrel 600 Holley double pumper on his slant. He put some really big valves in it and bored it .090 over with tall cam. He runs 14.02 in the quarter with a 3 speed tranny and street tires.
PostPosted: Thu Jul 24, 2008 6:58 pm
i am going for a streetable race car if that makes sence
you know what i mean
PostPosted: Thu Jul 24, 2008 9:45 pm
Why not?
I am not sure how many streetable race cars out there get good mileage, but I know a few guys have found that their engines are pretty potent and get still get some pretty amazing mileage.
PostPosted: Fri Jul 25, 2008 4:36 am
fineily someone who dosent think i am crazy. my dad just dont think im crazy but he dosent like all that power. but my frends think i am crazy hopping up a 6 cylender there like "should of had a v8" then hit me on the head
Users browsing this forum: Bing [Bot], Charrlie_S, Google [Bot] and 22 guests
