| '66 Slant6 and A833 4 speed https://slantsix.org/forum/viewtopic.php?t=30171 |
| Author: | RossKinder [ Thu Jul 24, 2008 11:27 am ] |
| Post subject: | '66 Slant6 and A833 4 speed |
Assuming the right BH, etc., if I had an 18 spline A833 4 speed would it suffice to get an 18 spline pressure plate or would there be a pilot problem too? For that matter, would the 23 spline tranny pilot fit up right? I see a lot about the bearing retainers, but little about pilots. Thanks. |
| Author: | DusterIdiot [ Thu Jul 24, 2008 7:26 pm ] |
| Post subject: | Err... |
I don't think there would be a pilot bearing problem as the splineage would be the problem... Mopar pilot bushings are pretty much the same, the problem lies in getting an 18 spline clutch disk for a slant six... you probably could come close with the 11" clutch disk and using a truck bellhousing and the large flywheel... the 'stocker' disks for our engines are all 23 spline and 9.25 or 10"... more than likely you could sell the 'hemi box' for a nice 1974-ish A-833 from a V-8 duster, and still afford a nice clutch setup, bellhousing, and the linkage -D.Idiot |
| Author: | RossKinder [ Sat Jul 26, 2008 11:10 am ] |
| Post subject: | Re: Err... |
Quote: I don't think there would be a pilot bearing problem as the splineage would be the problem...
I hear the 23 spline units are more common anyway. I'd probably need to avoid V-8 boxes (with short ratios), given my rear end ratio and wheel size.Mopar pilot bushings are pretty much the same, the problem lies in getting an 18 spline clutch disk for a slant six... you probably could come close with the 11" clutch disk and using a truck bellhousing and the large flywheel... the 'stocker' disks for our engines are all 23 spline and 9.25 or 10"... more than likely you could sell the 'hemi box' for a nice 1974-ish A-833 from a V-8 duster, and still afford a nice clutch setup, bellhousing, and the linkage -D.Idiot My big problem is how to look into the details of a transmission on the other side of the state or country. Most contacts I have are plain old junk yards with no particular Mopar expertise. Thanks |
