| timing chain/cam degreeing question https://slantsix.org/forum/viewtopic.php?t=30255 |
| Author: | pinkiedog64 [ Mon Jul 28, 2008 11:29 am ] |
| Post subject: | timing chain/cam degreeing question |
I have a double roller timing chain set from JP Performance and lost the instruction sheet for it ( |
| Author: | 66aCUDA [ Tue Jul 29, 2008 6:09 am ] |
Stephan You will be MUCH happyer if you just degree the cam!!!! Do a search for degreeing a cam. Frank |
| Author: | terrylittlejohn [ Tue Jul 29, 2008 6:24 am ] |
yes degreeing is the better way, also watch the marks you use there will be a 0mark on the tooth and another 0mark on the keyway to be used but line up the two 0marks that are on the gear teeth not the keyway. |
| Author: | 66aCUDA [ Tue Jul 29, 2008 6:29 am ] |
Stephan I have a degree wheel one of the guys on here made. You can Have/use it with the stipulation that you send it to someone else "free" when you are done. PM me with your address if interested. Frank |
| Author: | walpolla [ Tue Jul 29, 2008 7:36 am ] |
pinkiedog, I have sent you an email with an article about degreeing a cam. I do'nt know how to change format to post it here. regards,Rod |
| Author: | pinkiedog64 [ Wed Jul 30, 2008 8:36 pm ] |
Thanks for the responses and advice. I am all for degreeing the cam, I just wanted to initially set the timing gear to 0* for the degreeing process and had forgotten whether to line the dot on the cam pulley up with the 0* mark on the keyway, or the 0* mark at the teeth. Does someone happen to still have the JP Performance double roller timing chain instructions? Thanks again, Stephan |
| Author: | terrylittlejohn [ Thu Jul 31, 2008 5:37 am ] |
to set it at zero or straight up, you line the cam tooth and crank tooth zero marks pointing at each other but make sure the keyway marked zero is on the keyway. |
