MiDi's engine fiasco
https://slantsix.org/forum/viewtopic.php?t=30291
Page 1 of 13
Author:  MiDi [ Wed Jul 30, 2008 4:23 pm ]
Post subject:  MiDi's engine fiasco
i needed to back my dart out the driveway this morning so i could move my truck. and the dart started make'n a awefull noize.
please watch the video and listen.
http://s113.photobucket.com/albums/n212 ... 000486.flv
i was all set to race @ woodburn next weekend too, my wife goldyn was even gonna come with and hang out. with my car sounding like this, it is going no where! any idea's on what is wrong? and what can i do to fix it asap! the crazy part is my dart was just fine 2 days ago it sounded awesome and hauled A$$ in style like it normally does.
%$@! i almost was ready to fix the spedo cable and buy a disk break conv. off of craigslist. this is a major setback.
Author:  Fopar [ Wed Jul 30, 2008 4:33 pm ]
Check for blown exhaust gasket under side of manifold to head.
Author:  SlantSixDan [ Wed Jul 30, 2008 4:34 pm ]
Tough to say from the vid. I would agree, though, it sounds like it might be an exhaust manifold leak (maybe blown gasket, more likely broken manifold).
Author:  MiDi [ Wed Jul 30, 2008 4:39 pm ]
thanks for the advice fopar, but it looks good infact brand new. i sprayed some stuff on there to check it. is there another way to check that. i am about to pull the valve cover and see whats up, the sound seems to come from the valve cover or water pump. but again i have no idea wtf i am doing.
Author:  Joshie225 [ Wed Jul 30, 2008 4:45 pm ]
Sounds like an exhaust leak to me too. Bent pushrods usually aren't that loud. With the engine cold start it up and see if you can feel a leak. Should be obvious by the amount of noise it's making.
Author:  MiDi [ Wed Jul 30, 2008 5:02 pm ]
just to make my self happy i pulled the valve cover and everything looks good. i turned the fan and watched the valves go up n down. i am gonna go get a valve cover gasket then check for leaks. but i have looked it over and it does seem fine. what am i looking for?
Author:  terrylittlejohn [ Wed Jul 30, 2008 5:03 pm ]
start pulling plug wire while she running and see if you can track the sound to one cylinder, sounds like one cylinder is dead to me ?
Author:  Fopar [ Wed Jul 30, 2008 5:41 pm ]
You might try squirting some oil into the carb enough to create some smoke out the exhaust. The leak if there is one, will be visible.
Author:  MiDi [ Wed Jul 30, 2008 7:04 pm ]
i just got off the phone w/ Ceej and he and i agree its a rod.
so i think today is the sadest day of my life. :cry:
Author:  ceej [ Wed Jul 30, 2008 7:13 pm ]
See if you can get Josh down sometime to give it a listen.
It's pretty hard to diagnose from the video.
CJ
Author:  Guest [ Wed Jul 30, 2008 7:36 pm ]
If it's a pushrod just replace it, it's really easy all you need to do is remove the valve cover...
I'm in Vancouver, WA if you need one and can't find one i'll give you one, stock length.
Author:  MiDi [ Wed Jul 30, 2008 8:43 pm ]
well i just did just that. no leaks!
some nice smoke out my tail pipe but that was all.
Author:  Fopar [ Wed Jul 30, 2008 8:59 pm ]
you do have a mechanical fan, Maybe it's blowing the smoke away be fore it shows. try blocking the tail pipe some (about 1/2 way).
Just hoping for the best for you.
Author:  MiDi [ Wed Jul 30, 2008 9:01 pm ]
thanks fopar
Author:  RDJ [ Thu Jul 31, 2008 7:27 am ]
Before you tear into your engine, check to see if your converter bolts have loosened. More than one person (including me) have mistaken loose converter bolts for more serious engine problems.
Page 1 of 13 All times are UTC-07:00
