| Confirm or refute? https://slantsix.org/forum/viewtopic.php?t=30366 |
| Author: | RossKinder [ Sun Aug 03, 2008 4:39 pm ] |
| Post subject: | Confirm or refute? |
I just read that in 1975 A-833 overdrives were first made for A bodies and that in that same year all A/B body non-overdrive A-833's were discontinued. This would seem to mean that ANY 1976 and up A-833 for A bodies or B bodies is an overdrive transmission. (Don't know where B ends and E begins.) Am I missing something? Thanks PS. What is a G/RG block? |
| Author: | DusterIdiot [ Sun Aug 03, 2008 6:31 pm ] |
| Post subject: | Hmmm.... |
G/RG Block is a slant six... 'G' is a 170 (short deck) RG- is a 198/225 (tall deck) E is any 1970-1974 Barracuda/Challenger... B is Chargers, Satellites, Coronets, 78-79 Magnum, 68-75 Road Runner, Belverdere, GTX, 77-78 Monaco (not royal monaco), 75-79 cordoba, 75-78 Fury Only a few are going to have a 4 speed transmission as the muscle cars waved bye bye in 1974... and most were equipped as family barges (i.e 318/A904... or 400/727)... Yes, any 1976-1980 A-833 for Dart/Valiant variants, and Aspen Volare variants will be OD... -D.Idiot |
| Author: | RossKinder [ Mon Aug 04, 2008 8:10 am ] |
| Post subject: | Re: Hmmm.... |
Quote: Yes, any 1976-1980 A-833 for Dart/Valiant variants, and Aspen Volare variants will be OD... -D.Idiot Thanks |
| Author: | volaredon [ Tue Aug 05, 2008 2:03 pm ] |
a couple of possibilities; The trans has been swapped in the last 32 years which means it could be either OD or non OD; I've had both versions of the cast iron transmission. The OD came in both alum and C.I. (I had a cast iron 833 OD out of an early 80s van) |
| Author: | DusterIdiot [ Tue Aug 05, 2008 6:22 pm ] |
| Post subject: | The new problem... |
Quote: The trans has been swapped in the last 32 years which means it could be either OD or non OD; I've had both versions of the cast iron transmission.
unless you can visually inspect it and see if it's stock, and the front shift toggle is pointing 'down' and the reverse and 1-2 shift toggles are pointing up when bolted to the mechanism... then it could be anything swapped under there... I just freaked out a chevy guy at the shop with my '67... it still has the column shift lever for the A904... but I swapped in an A-230... and have a 3spd floor shifter... I just told him I have a 3-spd car... he's still trying to figure whether I meant 3spd manual or auto.... pictures and a saturday drive are 9/10ths of the fun of getting the right part to do the job... -D.Idiot |
| Author: | InThePink [ Tue Aug 05, 2008 8:12 pm ] |
Quote: Quote: Yes, any 1976-1980 A-833 for Dart/Valiant variants, and Aspen Volare variants will be OD... -D.Idiot Thanks Ask the seller to get the characters off the raised pad on the pass. side of the main case- that will tell you what it originally came in and if it's original to the car. |
| Author: | RossKinder [ Tue Aug 05, 2008 10:42 pm ] |
Quote: Quote: Quote: Yes, any 1976-1980 A-833 for Dart/Valiant variants, and Aspen Volare variants will be OD... -D.Idiot Thanks Ask the seller to get the characters off the raised pad on the pass. side of the main case- that will tell you what it originally came in and if it's original to the car. |
