| 6/8 bell housing? https://slantsix.org/forum/viewtopic.php?t=30394 |
| Author: | RossKinder [ Tue Aug 05, 2008 9:48 am ] |
| Post subject: | 6/8 bell housing? |
At: http://www.wicken-racing.com/Parts_for_Sale_Page.html they show bell housings said to work both on 318's and Slant 6's. I'd never heard of a bell housing that fit both Slant 6's and any V-8 engine. I emailed the people suggesting a mistake and they insist that this BH has two sets of holes - one for the Slant 6 and one for the V-8. Hm. Whaaaaaaa? Thanks |
| Author: | Joshie225 [ Tue Aug 05, 2008 10:25 am ] |
That's a truck only bellhousing. Very large and heavy. Won't fit under passenger car floor, uses different clutch release mechanism, and has a low mounted starter. |
| Author: | Greg Ondayko [ Tue Aug 05, 2008 10:27 am ] |
Bell Housings #2899163 (date G149) CWC fits 318, LA318 and Slant six $40 Bell Housings #2402698 (date A84) fits 318, LA318 and Slant six $40 Bell Housings #2235714-1 (date D48) fits 318, LA318 and Slant six This is what they have listed.. Maybe they are some of the Ginormous Truck BH's.. Who knows the Part #'s?? It isnt an a-Body Piece for sure. No pictures desent help either! Greg |
| Author: | RossKinder [ Tue Aug 05, 2008 10:52 am ] |
Quote: That's a truck only bellhousing. Very large and heavy. Won't fit under passenger car floor, uses different clutch release mechanism, and has a low mounted starter.
Perhaps this is too obvious to post, but... It must be huge at the back end, because the front end is said to fit the same old /6.Thanks |
| Author: | Joshie225 [ Tue Aug 05, 2008 10:54 am ] |
The front is also bigger because the bellhousing face of a small block is bigger than the slant six. You have to reach into the bellhousing to bolt it up to a slant. The small block bolt holes are on the periphery. |
| Author: | RossKinder [ Tue Aug 05, 2008 11:39 am ] |
Quote: The front is also bigger because the bellhousing face of a small block is bigger than the slant six. You have to reach into the bellhousing to bolt it up to a slant. The small block bolt holes are on the periphery.
Yuk and thanks.
| Author: | rock [ Wed Aug 06, 2008 5:58 am ] |
| Post subject: | I have been trying to give one away for a while |
As usual, Joshie has it described well. I have one left over from the great truck project and I have been trying to give it away for several years. I remember how shocked I was thinking I had it all undone, only to have to jack it up and go back inside to unbolt it. Even though mine was hot tanked no one is taking it...because of weight I reckon. It is about all you want to pick up by yourself! I think I am gonna add it to the old block and misc. cast iron parts and take it all to the metal buyer... rock '64d100 |
| Author: | RossKinder [ Wed Aug 06, 2008 8:58 am ] |
| Post subject: | Re: I have been trying to give one away for a while |
Quote: As usual, Joshie has it described well. I have one left over from the great truck project and I have been trying to give it away for several years. I remember how shocked I was thinking I had it all undone, only to have to jack it up and go back inside to unbolt it. Even though mine was hot tanked no one is taking it...because of weight I reckon. It is about all you want to pick up by yourself!
Oh come now. When I was only 3 I could carry a Model A engine and gear box from the front yard to the back yard all by myself with a Jack Daniels in one hand - and not even have to clean my overalls!!
| Author: | nasstee pink dart [ Sat Aug 23, 2008 9:50 pm ] |
Quote: As usual, Joshie has it described well. I have one left over from the great truck project and I have been trying to give it away for several years. I remember how shocked I was thinking I had it all undone, only to have to jack it up and go back inside to unbolt it. Even though mine was hot tanked no one is taking it...because of weight I reckon. It is about all you want to pick up by yourself! I think I am gonna add it to the old block and misc. cast iron parts and take it all to the metal buyer...
Hey if you want to give that away I will be in the Carolinas end of October. I will definitely take it off your hands. I pulled one of these out of the junkyard about 10 years ago but it doesn't have the bottom portion. I have been looking for another so I can complete a project.
rock '64d100 |
| Author: | rock [ Sun Aug 24, 2008 6:47 am ] |
| Post subject: | You got it! |
Hello, I live in Raleigh, pretty easy to get to from about anywhere. You can sure have it! It was hot tanked and stored dry. I took it out last weekend to put the starter on that Gmader was looking for. Heck you oughta take the starter too. And the crank that was polished, checked out and balanced. And a good drool tube head that was magnafluxed and hot tanked. Might be good for you to email me your regular address so I can send you a pic or 2 so we are both sure the belll is what you want. My address is rock at intrex dot net rock '64d100 |
| Author: | nasstee pink dart [ Sun Aug 24, 2008 11:26 pm ] |
| Post subject: | e-mail sent |
I sent you an e-mail. If will be under Justmoretrashmail. |
