Silly question : screw on reman. M/C
https://slantsix.org/forum/viewtopic.php?t=30418
Page 1 of 1
Author:  marc426 [ Wed Aug 06, 2008 11:47 pm ]
Post subject:  Silly question : screw on reman. M/C
Hello everyone,
I just received my reman. M/C and there is a screw with a little piece of metal holding the piston inside and I had that really silly question : should I remove it???
Thanks for your help!
Marc
Author:  digger12 [ Thu Aug 07, 2008 1:54 am ]
sounds like its for transport purpose only.
Author:  emsvitil [ Thu Aug 07, 2008 2:34 am ]
If there's no clipring to hold the piston in, I'd leave it.......
Author:  65 dartman [ Thu Aug 07, 2008 3:39 am ]
I've got several original M/C's and they all have the screw and little clip. It's to hold the piston from coming out.
Author:  SlantSixDan [ Thu Aug 07, 2008 7:38 am ]
It's there to indicate that by buying a "remanufactured" master cylinder, ya done got screwed. :lol:
Author:  volaredon [ Thu Aug 07, 2008 9:45 am ]
Some of you might have seen my posts (I believe in "other" category) from the last couple weeks regarding a reman booster/master that I bought for my Fury? One of the 1st things I noticed between the reman M/C and the orig (which is back on the car, bolted to the reman booster and working well) was that in the forward chamber (controls rear brakes, "forward" means closest to front of car) the original MC had a Phillips head screw in the bottom of the fluid reservoir, next to the inlet hole that admits fluid into the M/C's chamber, that the reman did not; my 1st thought was part number consolidation knowing that this same M/C fit lots of years and models of cars; (the rebuilders always talk of "product improvement" in the reman process after all) now that the reman M/C is on the floor under the workbench and the orig one back on the car, I'm wondering if that had anything to do with my having to put the orig one back on there in the 1st place
