2bbl swap help please
https://slantsix.org/forum/viewtopic.php?t=30448
Page 1 of 2
Author:  1970dart225six [ Fri Aug 08, 2008 4:28 pm ]
Post subject:  2bbl swap help please
i have a 1970 225 slant six dart, it was a single carb, and i have begun to switch it to two barrel i have changed the intake and exhaust manifolds and have mounted the car but i cant figure out to mount all the conection for the throttle etc and i am installing a manual choke if u know how to do these things can tell me how or send me a pic of how it looks done!
Author:  Aggressive Ted [ Fri Aug 08, 2008 5:31 pm ]
Do you need more picks than what is posted on the front page????
Mopar Slant Six, "Super Six" Two Barrel System
By Reed Speir ("Reed")
Edit & webpage layout by Doug Dutra (Doctor Dodge)
Those aren't that bad. What specifically are you having problems with?
Do you have the FSM for a 1976 or 77 Super Six?
Author:  MiDi [ Fri Aug 08, 2008 7:39 pm ]
i agree that the super six article is extermely usefull. i printed it out and have read it prolly 100 times.
here is what my super six looks like
custom throttle cable bracket made my ceej and fopar. i use a lokar cable insted of a kick down. the throttle return spring bracket is off a v-8 kick down that i modifed to work. slantsixdan has posted an awesome electric choke kit for the 2bbl in the slanted network part of this forum.
Author:  ESP47 [ Fri Aug 08, 2008 10:07 pm ]
These aren't mine but they're just some of the photos I used for reference when I put my super six setup on.
Author:  1970dart225six [ Fri Aug 08, 2008 10:43 pm ]
hey thanx for the pics guys, on my car there seems to be a rod that goes to the tranny just under the fire wall(drivers side) it was attached before but after i attached the new carb do i need that-wat ever it is--anymore?
i think its just a kickdown linkage but i dont seem to need it, but im not really sure
ESP47 posts have it some how rigged up? but wat is it?
Author:  dakight [ Sat Aug 09, 2008 7:40 am ]
If I understand you correctly, that is the kickdown linkage for the automatic tranny. If you have an automatic then you need it; if you have a manual then you don't
Author:  Reed [ Sat Aug 09, 2008 8:10 am ]
Hello and welcome.
First, read this article. It will answer most of your questions about converting from a one barrel to a two barrel.
Here is how the linkages attach to the carb:
You must also adjust the kickdown linkage once it is installed:
Good luck and feel free to ask any more wuestions!
Author:  ESP47 [ Sat Aug 09, 2008 10:52 am ]
If i'm reading you correctly, you have the old 1 BBL kickdown linkage. You're gonna need a 2 BBL kickdown with all the brackets to make your super six shift right. Your old linkage won't work and I wouldn't recommend driving it much without a new linkage.
Author:  1970dart225six [ Sat Aug 09, 2008 1:06 pm ]
yea i have the old 1 barrel kickdown, how much would it be to get all the brackets etc for the two barrel and the kickdown?
Author:  SlantSixDan [ Sat Aug 09, 2008 1:12 pm ]
The 2bbl kickdown linkage setups are getting tough to find and costly. See this thread for kickdown options.
Author:  ESP47 [ Sat Aug 09, 2008 3:31 pm ]
http://tinyurl.com/5jmxdb
Thats the only one I could find on ebay. It's very pricey. I think people are fooled because he did a good job cleaning it up. They don't usually go for that high but if you need one now then your options are slimmer.
Author:  dusterguy225 [ Sat Aug 09, 2008 3:51 pm ]
Wow, ESP47, your right, that is very pricey. I bought my super six set up, that I plan to rebuild, from a pull a part in nashville for $40! And its complete!
Author:  1970dart225six [ Sat Aug 09, 2008 3:53 pm ]
ive been making my own addapter for the single carbs kickdown to the 2 barrel and its actually working very well i will post pics when im done, thanx for the help!
by the way im 17 and this is my first car :D
Author:  MiDi [ Sat Aug 09, 2008 4:14 pm ]
http://www.lokar.com/interior_pages/tc_kd.htm
Author:  Aggressive Ted [ Sat Aug 09, 2008 8:05 pm ]
Midi,
Which one did you use? Do you have a part number?
Page 1 of 2 All times are UTC-08:00
