| mating an OD 4spd to a non-OD 4spd *PIC* https://slantsix.org/forum/viewtopic.php?t=3055 |
| Author: | Doug Ahern [ Wed Jan 02, 2002 10:51 am ] |
| Post subject: | mating an OD 4spd to a non-OD 4spd *PIC* |
Here is a picture of an OD-bellhousing that has been fitted with an adapter ring to accept the smaller 4.35" input bearing retainers. this was done by a machine shop 10-15 years ago. link to image ![]() doug@autohobbydigest.com |
| Author: | Doug Ahern [ Wed Jan 02, 2002 10:53 am ] |
| Post subject: | Re: mating an OD 4spd to a non-OD 4spd *PIC* |
oops... heres the actual image.... ![]() doug@autohobbydigest.com |
| Author: | Mike Andreas [ Wed Jan 02, 2002 5:46 pm ] |
| Post subject: | Aonther Solution |
I talked to Dennis at Wildcat MOPARS and he sent me a bearing retainer that came from a 3 speed something that has the O/D outside diameter and has a 3.7" bolt circle. I had it blasted and replaced the seal. I don't have the car assembled yet but it looks like it will work fine. I don't think he ever said what it came from but if you asked, I'm sure he'd let you know. Mike MAndreas@aol.com |
