| changing stove box gasket https://slantsix.org/forum/viewtopic.php?t=30557 |
| Author: | mrsocks6 [ Thu Aug 14, 2008 5:35 pm ] |
| Post subject: | changing stove box gasket |
how do i change the stove box gasket on my 225? |
| Author: | Joshie225 [ Thu Aug 14, 2008 7:20 pm ] |
Remove the manifolds from the engine and and unbolt them from each other. |
| Author: | RDJ [ Fri Aug 15, 2008 9:43 am ] |
Get one of the Australian or Remflex gaskets, they seal way better than the stamped steel gasket. |
| Author: | Doc [ Fri Aug 15, 2008 10:26 am ] |
See the SL6 manifold installtion article for tips on how to prep and re-assemble the manifold set. DD |
| Author: | 65Dodge100 [ Fri Aug 15, 2008 4:36 pm ] |
HERE is the slant six manifold installation article. Here are a couple of good threads about gaskets: http://tinyurl.com/6lqjcs http://tinyurl.com/68wgku You may also want brass nuts - Dorman Part # 680-001 or 849-001 (same nut, sold to stores in different packages) And new studs (Grade-eight) - Dorman Part # 675-093 And new castellated nuts for the end studs Part #AN310-5 (5/16-24) at this website Danny |
