It is currently Thu May 21, 2026 1:36 am
PostPosted: Thu Aug 14, 2008 5:35 pm
how do i change the stove box gasket on my 225? :?:
PostPosted: Thu Aug 14, 2008 7:20 pm
Remove the manifolds from the engine and and unbolt them from each other.
PostPosted: Fri Aug 15, 2008 9:43 am
Get one of the Australian or Remflex gaskets, they seal way better than the stamped steel gasket.
PostPosted: Fri Aug 15, 2008 10:26 am
See the SL6 manifold installtion article for tips on how to prep and re-assemble the manifold set.
PostPosted: Fri Aug 15, 2008 4:36 pm
HERE is the slant six manifold installation article.
Here are a couple of good threads about gaskets:
http://tinyurl.com/6lqjcs
http://tinyurl.com/68wgku
You may also want brass nuts - Dorman Part # 680-001 or 849-001 (same nut, sold to stores in different packages)
And new studs (Grade-eight) - Dorman Part # 675-093
And new castellated nuts for the end studs Part #AN310-5 (5/16-24) at this website
Danny
Users browsing this forum: Google [Bot] and 14 guests
