| 225 parts in a 170 https://slantsix.org/forum/viewtopic.php?t=30566 |
| Author: | jibs1723 [ Fri Aug 15, 2008 7:32 pm ] |
| Post subject: | 225 parts in a 170 |
i have a 64 valiant with what i was told was a 225. I was having some timing issues and a cam lobe was going down so i ordered a new cam and timing set. Once i got the head off something didn't look right and when i measured the stroke, sure enough its a 170. the problem is that i already have the parts that are for the 225. Will they work in the 170? thanks |
| Author: | slantzilla [ Fri Aug 15, 2008 7:35 pm ] |
Cam and timing set will interchange. Pushrods would be different if you got those. |
| Author: | Joshie225 [ Fri Aug 15, 2008 7:46 pm ] |
Lots of 170 and 225 stuff is common. It's probably easier to list what won't interchange. Block, crank, rods, pushrods. |
| Author: | Charrlie_S [ Fri Aug 15, 2008 8:12 pm ] |
With a 170 make sure to check the valve to piston clearence, if installing a bigger cam, and milling the head. |
