| break springs https://slantsix.org/forum/viewtopic.php?t=30581 |
| Author: | theslantingsix [ Sat Aug 16, 2008 3:59 pm ] |
| Post subject: | break springs |
i got a spring kit for my 10 inch rear drums and it did not come with the one spring that i need |
| Author: | KBB_of_TMC [ Tue Aug 19, 2008 9:18 am ] |
I think you're referring to the oval anti-rattle spring on the parking brake strut. It is very standard - many models, years, brands will interchange fine. I got a brake kit from Paddock made by Rabestos that included them, but I'm pretty sure any good parts place can still get them. I also recall having seen them in the blister packs, so carry the broken one or a ruler along. Many brands and years look a little different, but work the same. Some places carry the parts, but can't look them up, so you've got to know what it looks like. |
| Author: | theslantingsix [ Tue Aug 19, 2008 10:47 am ] |
thanks so much i went all around town to napa autozone carquest and the hardware store and i was so angry |
| Author: | KBB_of_TMC [ Thu Aug 21, 2008 10:45 am ] |
The antirattle spring is probably not something a hardware store would carry, but I've found that AMCs, Fords, and Mopars use about the same spring and in a pinch you should be able to substitute one for another. The kits I've looked at online don't seem to carry that spring, so you may have to hit a junkyard or take a holddown or similar spring and gently squeeze it in a vice until it has about the proper shape. It isn't a very stiff. |
| Author: | SlantSixDan [ Thu Aug 21, 2008 11:07 am ] |
Weird. Guess this is yet another example of parts quality continuing to fall to 3rd-world levels. Last aftermarket drum brake hardware kits I looked at were made in China, too. A hold-down or other spring could not readily be properly modified to act as an antirattle spring, I don't think. If all else fails, the factory p/n for this spring is 4773 942. Complete Chrysler hardware kit is p/n 4636 772, and includes the antirattle spring. |
| Author: | theslantingsix [ Thu Aug 21, 2008 12:01 pm ] |
i finily found em yesterday at summners automotive in burlington N,C and they had em in stock |
