Dimmer switch tech article??
https://slantsix.org/forum/viewtopic.php?t=30602
Author:  ValiantOne [ Mon Aug 18, 2008 7:17 am ]
Post subject:  Dimmer switch tech article??
Hey All,
I remember reading a tech article about fixing the dimmer function on the headlight switch. I checked the article section here on /6.org, and no luck. I can't remember where the heck I found the article !!!
I have to pull my instrument panel to fix other things and would really like to get the dimmer working. If this article rings a bell to anyone I'd really appreciated it!
Thanks,
CE
Author:  SlantSixDan [ Mon Aug 18, 2008 9:38 am ]
Replace the switch. If the dash light rheostat is dead or dying, the rest of the switch isn't far behind.
Author:  Jopapa [ Mon Aug 18, 2008 10:51 am ]
Which brand do you recommend? Standard, Delco?
Author:  ValiantOne [ Mon Aug 18, 2008 5:08 pm ]
Holy Cow! It never even occurred to me that a new switch may be available.
I'll be calling napa tomorrow to see what is available.
CE
Author:  SlantSixDan [ Mon Aug 18, 2008 5:22 pm ]
Standard or Echlin would be a good choice.
Author:  KBB_of_TMC [ Tue Aug 19, 2008 9:29 am ]
Maybe you were thinking of these links:
http://www.tidewatermoparclub.com/TECH/dimmer3c.pdf
or
http://www.tidewatermoparclub.com/TECH/ ... icable.pdf
Sometimes you just can't buy a new part... so it's good to get some practice when you can.
Author:  rebel_cat68 [ Tue Aug 19, 2008 12:12 pm ]
Summit Racing:
Replacement headlight and dashlight dimmer switch
Standard Motor Products DS357, $24.95
Author:  ValiantOne [ Tue Aug 19, 2008 5:48 pm ]
or
It wasn't either of those but Thank You! That will be some good reading!
CE
Author:  ValiantOne [ Tue Aug 19, 2008 5:49 pm ]
Summit Racing:
Ain't that something? That is what i get for assuming...........
Thank you!
CE
Author:  lindross [ Wed Aug 20, 2008 6:03 am ]
I found this at O'Reilly for a 63 Valiant for $19.99. Does this look about right for those who have seen them? I haven't pulled mine down yet but it needs replaced.
link
Author:  lindross [ Thu Aug 21, 2008 6:06 am ]
Guess I'll answer my own question, but yep it worked great! :D
