| broken choke stove bolts https://slantsix.org/forum/viewtopic.php?t=30623 |
| Author: | mrsocks6 [ Mon Aug 18, 2008 6:37 pm ] |
| Post subject: | broken choke stove bolts |
does anyone have a source on the web for choke stove bolts? |
| Author: | SlantSixDan [ Mon Aug 18, 2008 10:16 pm ] |
Plain ol' ordinary hardware store items. |
| Author: | MiDi [ Tue Aug 19, 2008 12:03 am ] |
yep old hardware store parts bin, i have even boken a few off and drilled / tapped em out to a slightly bigger size, and replaced with grade 8 hardware store ones. |
| Author: | SlantSixDan [ Tue Aug 19, 2008 12:15 am ] |
PS, buy one of the Electric choke kits and you'll only need one bolt, the "rear" one closest to the cylinder head...unless you have a '70-'72 exhaust manifold, in which case you must use two bolts at this location to avoid an exhaust leak. |
| Author: | Guest [ Tue Aug 19, 2008 9:01 am ] |
Or get a manual choke.. |
| Author: | steponmebbbboom [ Tue Aug 19, 2008 3:38 pm ] |
the original choke stove bolts were stainless steel which were far less likely to seize in the cavities. |
